Author Topic: Broken Screw on Carb Slide  (Read 1110 times)
Offline cb_n00b
« on: March 21, 2018, 08:25:09 AM »
Had an old screw break off in the slide linkage. Any suggestions on how to get it out?
See attached picture.
1977 CB550K
- MotoGP Werks Exhaust / Stock Airbox
- Dyna S Ignition & Coils
- Motogadget M-Unit Blue
- 069A CB550F Carbs
- Beringer front brake kit
Offline Paintedseat
Re: Broken Screw on Carb Slide
« Reply #1 on: March 21, 2018, 10:58:38 AM »
Drill it tap it.
Offline DaveBarbier
« Reply #2 on: March 21, 2018, 11:52:26 AM »
Drill it tap it.
Left hand drill bit after soaking with PB Blaster and heat. That’s what I’d do.
Offline Dos
  • Owner of a cb350f
« Reply #3 on: March 21, 2018, 12:01:16 PM »
Haha wow the same thing just happened to me.
I am using a drill bit and unscrewing to the left,
I am having trouble finding a replacement though. Do you know where I can get one?
Offline cb_n00b
« Reply #4 on: March 21, 2018, 03:23:57 PM »
Got the bastard! Let’s never have to do that again...
1977 CB550K
- 069A CB550F Carbs
Offline cb_n00b
« Reply #5 on: March 21, 2018, 04:18:09 PM »
Dos, I picked up a set of 4 from Lowe’s. Think it was $1.50 maybe. They’re M4 .70 x 12.
1977 CB550K
- 069A CB550F Carbs
Offline Dos
  • Owner of a cb350f
« Reply #6 on: March 21, 2018, 06:18:50 PM »
I got mine out too!
And thank you for those dimensions!!!
Offline Dos
  • Owner of a cb350f
« Reply #7 on: March 21, 2018, 06:19:34 PM »
My carbs are from a cb350f though, same size you still think?
Offline cb_n00b
« Reply #8 on: March 22, 2018, 04:53:28 AM »
No idea. Can’t say I’ve ever been in a set of 350 carbs.
Good luck!
1977 CB550K
- 069A CB550F Carbs
Offline Dos
  • Owner of a cb350f
« Reply #9 on: March 22, 2018, 02:47:44 PM »
I was only able to find these locally do you think the circular head will mess things up because I won’t be able to put the clip around it?
I could also just Dremel it into a hexagon head what do you think?
