Author Topic: Tank Paint Job  (Read 2107 times)
Offline JonathanHValencia
Tank Paint Job
« on: March 21, 2018, 03:17:01 PM »
Hey guys,
I got a tank I want to paint on a budget. I ordered a tank online and it could use a touch up. It was recently primed and painted. I don’t wanna strip it down to bare metal and prime it if I don’t have to. Any recommendations?
There is a small chip up front, over all it’s good, just kinda dulled it when I used electrolysis and prep n etch. Can I sand it some all over to the primer then paint over it?
Re: Tank Paint Job
« Reply #1 on: March 21, 2018, 03:56:55 PM »
Some spots I sanded down to bare metal
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Tank Paint Job
« Reply #2 on: March 21, 2018, 04:37:09 PM »
i'm not a paint expert but i would suggest fixing the chip with a bondo type product if it's very shallow.  then sand that spot well to blend it.  maybe some filler primer would be good to get you towards a top coat.  various stages of wet sanding between primer and top coats may be helpful for a nice finish.  i would suggest an automotive type paint.
cb750 k6 - ugly
Re: Tank Paint Job
« Reply #3 on: March 21, 2018, 04:48:46 PM »
It’s very superficial, especially after sanding it
I’m going to prime - sand - prime - sand then paint
Offline evinrude7
  • not a kung-fu
Re: Tank Paint Job
« Reply #4 on: March 21, 2018, 05:51:11 PM »
cool. post some photos when you get done.  make sure to clean after sanding.
« Last Edit: March 21, 2018, 05:52:46 PM by evinrude7 »
cb750 k6 - ugly
Re: Tank Paint Job
« Reply #5 on: March 21, 2018, 06:00:04 PM »
Clean with what? Just water and a rag?
Offline gto_ron
Re: Tank Paint Job
« Reply #6 on: March 21, 2018, 06:58:26 PM »
I'd wipe it down with wax & grease remover before sealing it with epoxy primer.  Get them at your local paint jobber or online.  The goal is to have a perfectly clean surface.
Post pictures so we can admire the tank when finished.
76 CB750K
72 CB350F
64 GTO
why yes, I am old-school, so what?
These are the good old days.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: Tank Paint Job
« Reply #7 on: March 21, 2018, 07:03:44 PM »
Yep, dish soap first, let dry, then wax & grease remover. If you can, prime it with the filler/ primer available at any auto parts store, its fairly easy to get a nice smooth finish. Just remember to use a sanding block or sanding sponge(block of stiff foam) with 600 grit wrapped around it, and wet sand it until low spots are apparent... dry, paint with filler/primer, and repeat until no low spots appear. Then wipe with wax and grease remover, tack cloth, and paint.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Xander^
Re: Tank Paint Job
« Reply #8 on: March 21, 2018, 07:05:11 PM »
i guess in the US its easy to get epoxy primer? i was looking for this earlier in my build (IN CANADA) and couldnt find it anywhere and the only ebay post i saw at the time was like 100$ for a can ... even a car body shop said they barely use it but can order it in (the compressor gun version).. any links to a spray can version?
1977 CB750K cafe
Offline Yamahawk
Re: Tank Paint Job
« Reply #9 on: March 21, 2018, 07:11:08 PM »
Epoxy primer is for sealing the old finish, and may not be necessary. It is also 2k (primer/hardener), not 1k. I myself, would just use filler/primer, but if you have a reaction to the old paint, there is a spray can of primer/sealer that should work. Spray gun 2k epoxy primer is rather expensive, and probably not necessary.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Xander^
Re: Tank Paint Job
« Reply #10 on: March 21, 2018, 07:12:50 PM »
Charlie
self-etching primer? how does that work on metals or chrome?
1977 CB750K cafe
Offline Yamahawk
Re: Tank Paint Job
« Reply #11 on: March 21, 2018, 07:43:04 PM »
Charlie
Not much works for painting chrome... It is best to leave it or re-chrome it, or strip it down to the base metal, and prime and paint... self-etching primer just gives your paint something to adhere to.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Re: Tank Paint Job
« Reply #12 on: March 21, 2018, 10:25:46 PM »
I should strip it to bare metal since you do not know which paint used. Then use good paint that are compatible.
When applying the nice topcoat it can react with the old and shrinkle... I know I have seen expensive paint react with the previous layers of paint in a really bad and expensive way. All were 2K and fresh.
This was long time ago and the paints have only became worse since then due to the green environmental forces removing all good chemicals, right?
Offline Yamahawk
Re: Tank Paint Job
« Reply #13 on: March 22, 2018, 07:01:20 AM »
Hehe Right!
I used a fine wire wheel on my 4" grinder from HF, the one with a slight curve to it, to remove the paint from my tank before painting it, worked well, and was able to use the primer/filler after a few hidden dents were filled and sanded with the gold Bondo. It came out fairly well. The new filler primers work good to spray, sand, and find where the low spots were.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
