Author Topic: Etch primer and filler primer  (Read 465 times)
Offline JonathanHValencia
« on: March 24, 2018, 01:02:04 AM »
Priming my bare metal tank. I first used an etching primer on the bare metal, then a filler primer next. Should I sand between the etch and filler or just spray the filet after the etch and sand only the filler primer?
Offline gtmdriver
Re: Etch primer and filler primer
« Reply #1 on: March 24, 2018, 03:44:57 AM »
Spray the etch primer on then put the filler primer on without rubbing down.
Check the data sheets. Some etch primers (especially the 'wash' type) need overcoating fairly quickly after spraying.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #2 on: March 24, 2018, 05:31:37 AM »
Correct. Read the labels carefully and follow the instructions for re-coat times. The filler/primer is always sanded, and you should try to get a different color than the etch primer so you can tell where the low spots are. the filler will wet sand off and leave its color in the low spot. When you see this, stop sanding, and wash tank and dry, then spray another coat, let dry for appropriate time for wet sanding, and repeat. Most important to follow instructions for the product you are using. Try to get tack cloths and use them lightly after drying to remove any specks of dirt, hair, etc. between coats, and especially before finish coats, and clear coats.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
