Author Topic: Front axle torque - how tight do I get the axle nut? - SOLVED  (Read 4320 times)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
I am installing my front axle in the ComStar rim getting ready to put it back into the fork lowers with the retainer caps. However, I remember that the axle nut was pretty tight when I removed it, and now, if I tighten it up past snug, it seems to bind in the front hub. If I snug it, and take all the play out of the axle, spacer, speedometer drive, etc. it spins in the hub fine. Is this correct, or is there something wrong? I had noticed before that the bike was a hard roller, especially backwards. Is it possible that the PO had the axle too tight in the hub, binding the bearings? I can't find any instructions but 'tighten the axle' in the hub prior to assembly in the forks. I understand the fork lower caps capture both ends of the axle, so is 'snug' good, or is there a problem with my bearings?I guess the wheel should spin on the axle, but should I install it and see if there is any binding, as the inner race, spacer, and axle should be tight together. Maybe I am just under thinking on this one lol. So. when I am tight, should the axle spin without force in the wheel hub?
Charlie
« Last Edit: March 25, 2018, 02:00:54 AM by Yamahawk »
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Erny
Re: Front axle torque - how tight do I get the axle nut?
« Reply #1 on: March 24, 2018, 09:07:59 AM »
Hi Charlie,
K7 specifies 5.5-6.5 kg-m (40-47 ft-lbs)
Both for K version and also F version (comstar) see attached pic from shop manual
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Yamahawk
« Reply #2 on: March 24, 2018, 09:25:16 AM »
Thanks, Erny, if i am this tight should the axle still spin in the hub? it is really hard to turn, or won't spin at all when i tighten the axle, yet both bearings spin with my finger when the axle is removed.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Erny
« Reply #3 on: March 24, 2018, 09:47:33 AM »
Well, actually my only experience is with my axle - it does not spin, if I try to rotate by hand. But I have stock, 42 years old bearings (9000 miles on them) that I plan to change, so I let it be for the moment. I did not disassemble it, so I suppose it is like that from new, never done
Offline Yamahawk
« Reply #4 on: March 24, 2018, 09:49:35 AM »
OK cool, I have re-installed the axle, torqued it tight, and put the caps back on the forks, and it seems to spin with a little drag, but not much. I will take it for a spin later, and see how it does, Thanks Erny!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline slikwilli420
  • Master of Disaster
« Reply #5 on: March 24, 2018, 09:54:20 AM »
Bearings should spin easily once torqued. If they don't something is binding.
Offline Yamahawk
« Reply #6 on: March 24, 2018, 12:11:37 PM »
Is this after installation in the front forks? or just the axle twisted by hand in the hub? I installed the axle back in the forks, and the wheel spins pretty well, not as free as other bikes, but it doesn't feel too bad. That is without the brake caliper on also.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #7 on: March 24, 2018, 01:14:01 PM »
Is your axle nut hex head on one end(?), make sure it is installed with the hex end closest to the wheel.(?)
the early 750 and 550 are like that and act like that if the nut is installed wrong way around.
« Last Edit: March 24, 2018, 01:18:28 PM by my name is nobody »
Offline Yamahawk
« Reply #8 on: March 24, 2018, 01:26:09 PM »
Yeah, the axle nut is with the flats on the hub side, so it is inside the fork leg. I didn't tighten up the lower fork cap nuts until I pumped the forks a couple times to center and relieve any fork binding also, then tightened the 2 cap nuts on each fork lower.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #9 on: March 24, 2018, 01:48:57 PM »
Speedo gear must be set in correct position, if not the wheel will lock up when tighten.
Offline Yamahawk
« Reply #10 on: March 24, 2018, 01:53:35 PM »
It did key in, and rotated the flat blade... if it wasn't keyed in, wouldn't it have not fit into the seal flush? I mean, wouldn't there have been a gap?
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline jgger
« Reply #11 on: March 24, 2018, 02:32:30 PM »
The standard for unknown bolt torque is tighten it until it starts to get loose again........then back off a quater to a half turn. You have been riding long enough to know that Charlie! Jeez
Offline przjohn
« Reply #12 on: March 24, 2018, 03:43:12 PM »
The wheel should spin freely with no feeling of drag. When the axle is mounted to the wheel will it spin freely holding the wheel in your hands? If there is any feeling of drag something is wrong. Is the spacer installed? The spacer may also be wrong, I have found pieces of pipe in wheels for spacers.
Offline Yamahawk
« Reply #13 on: March 24, 2018, 04:06:37 PM »
PeWe, you were correct, thought it keyed in but it was off a smidge, and it was binding, I took it out and straightened it, and now is working well.
Hehe I tried that, but was using too little of a wrench to get it to loosen up again, and my cheater was nowhere in sight...
Yep, the spacers were all proper, it was me, as the loose nut...
I now have a working wheel lol. Thanks everyone for the advice.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
