Author Topic: 77 CB550F swing arm bushings  (Read 1546 times)
Offline GardenGnome
  • 1977 CB550F
« on: March 25, 2018, 06:30:50 PM »
So I was in conversation with Calj727 about my swing arm being too tight to install. The conclusion that we came to was the bronze bushings were too thick white the dust caps go. It was recommended that To fix this issue to sand down the ends some to get them to fit correctly. While I agree that this would work, I am uncomfortable attempting this.
I am wondering what input there is towards the plastic looking ones from Davidsilverspares V.S. the bronze ones? If the bronze ones are more recommended where can I buy them so I don't have to do any modifying to them?
Thanks much for reading.
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline DaveBarbier
Re: 77 CB550F swing arm bushings
« Reply #1 on: March 26, 2018, 01:28:31 PM »
I bet you can find a machinist near you to turn them down a bit (you’d have to give him a measurement) for pretty cheap.
You could ship them to me if you want, I’ll do it for free. But I’m in CT 06468.
How much would they have to be reduced?
Offline shads
« Reply #2 on: March 27, 2018, 01:22:08 AM »
Gnome, Ive got a '77 550K3 (looks to have the same swingarm as yours) and ive got the same concerns about the using the bronze bushings - specifically im concerned that the lip on bronze bushing will be to thick/thin length-ways when compared to the OEM plastic ones.  Ive got the Kenosha Kid ones off ebay by the way.
Unfortunately, I chucked out the OEM plastic ones out shortly after removing them (didn't realise how tricky these old swingarms are at the time!), so don't have anything to measure.  Can you accurately measure the lip thickness of the OEM ones?  Ill report back what bronze ones are when I get a spare 5 mins to measure them.
Offline Smudgemo
  • Maker of Stuff
« Reply #3 on: March 27, 2018, 08:17:05 AM »
Just throwing out possibilities here.  Is the frame straight?
I had mine straightened and was told it had lived a "spirited" life.  Bought those same bushings (I presume) and it all went together just fine.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
« Reply #4 on: March 27, 2018, 10:37:56 AM »
I have a NOS set of plastic ones from a NOS CB750F0 swing arm that I could measure IF they are the same part number. I used Kenosha Kid's set instead without any problems but again my bike is a 750F.
Offline rosewood
« Reply #5 on: March 27, 2018, 01:27:16 PM »
I haven't rebuilt my swing arm yet but I was considering machining off the lip/shoulder of the bronze bushings so they would fit completely inside the swing arm and then installing the OEM plastic end caps that some models came with that didn't have the shouldered bush.
I have heard the the shoulders/lips on the bronze ones have a tendency to break.
Offline shads
« Reply #6 on: March 27, 2018, 02:44:55 PM »
Yeah, yours looks to be the same part number as the 77/78 550.  If you could measure the lip that would be really helpful!
https://www.cmsnl.com/honda-cb550-four-cb550k3-1977-usa_model1015/bush-rrforkpivot_52108457300/
« Reply #7 on: March 27, 2018, 02:49:34 PM »
Also - did you loosen the engine mounting bolts?  [if the motor is in the frame]
Try to get an accurate measurement, how much too wide is it?  This is not common.
« Reply #8 on: March 27, 2018, 03:21:07 PM »
They WERE hanging on my wall........... I'll have to do more digging in the basement archives.
The thickness of the lip is 1.8mm
« Last Edit: March 27, 2018, 03:30:55 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline shads
« Reply #9 on: April 05, 2018, 02:31:24 AM »
Ok, I just measured my bronze ones.  1.95mm lip.  So maybe they do need filing/turning down a bit.  Is 0.15mm on each side too much?
