Author Topic: Bench syncing 73 cb350f carbs  (Read 3338 times)
Offline Coredozer19
« on: April 02, 2018, 04:43:41 PM »
I know vacuumed sync is the best but I just want to get them close so I can get my idle in check. Any videos or advice on the subject?
1973 Honda CB350F
Offline innovativems
    • Innovative MotoSports
Re: Bench syncing 73 cb350f carbs
« Reply #1 on: April 02, 2018, 04:47:26 PM »
I use a 1/8 drill bit to bench sync mine
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Coredozer19
« Reply #2 on: April 02, 2018, 04:51:09 PM »
When bench syncing where do you set your idle adjustment screw
1973 Honda CB350F
Offline Flyin900
« Reply #3 on: April 02, 2018, 05:57:46 PM »
Download the FSM from the site and all the info is contained in there for your setup.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Coredozer19
« Reply #4 on: April 02, 2018, 06:00:21 PM »
I’m a noob what does FSM stand for.
1973 Honda CB350F
Offline Flyin900
« Reply #5 on: April 02, 2018, 06:05:55 PM »
Welcome noob!
Look under the manuals and tech section about four subjects down from the top on the Home Page. There are wonderful people who have taken the time to copy and load a complete Honda Factory Service Manual for your pleasure. (FSM)
You will find all the information on every facet of the bike including tune up and major and minor repair info.
Offline WhyNot2
  • I'm finally an
« Reply #6 on: April 02, 2018, 06:09:13 PM »
The 1/8th inch drill bit works great.
Offline Flyin900
« Reply #7 on: April 02, 2018, 06:13:49 PM »
The factory spec is 1mm not 1/8 of an inch and so too large as FYI 1/8 " = 3mm.
If you are using a drill bit a .040 micro drill bit is the correct size for the 1 mm spec.
Back the idle adjuster off completely so it isn't affecting the slides you want the slides sitting in their resting position with no idle adjuster engaged.
« Last Edit: April 03, 2018, 12:28:05 PM by Flyin900 »
Offline enwri
  • So that noise is normal?
« Reply #8 on: April 02, 2018, 06:34:51 PM »
Depends on what size drill bit you use, follow whatever the FSM says .
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline Coredozer19
« Reply #9 on: April 02, 2018, 06:43:23 PM »
Okay I have a clymer manual I wasn’t sure if it states how to bench sync carbs or not
1973 Honda CB350F
Offline enwri
« Reply #10 on: April 02, 2018, 07:08:07 PM »
As long as you can back off the idle speed adjuster enough to just close the throttles when you are finished. (if the guide doesn't say anything about it.)
8? XJ 550 meh...
Offline WhyNot2
  • I'm finally an
« Reply #11 on: April 03, 2018, 02:57:36 AM »
I benched synced mine a while ago, ran nice after, but I let it sit for a few years, brought it back to the front and now it pees all over the place.
Looks like carb removal is in the future again.
And they are a pain to remove and install.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #12 on: April 03, 2018, 06:29:07 AM »
use a paper clip stretched out.  follow this and you'll be fine.  http://www.hondachopper.com/garage/carb_info/bench_sync/bench_sync.html
cb750 k6 - ugly
Offline bhh1989
« Reply #14 on: April 09, 2021, 11:34:26 AM »
Trying to avoid starting yet another thread on this..  Been trying to piece together information from all these threads relevant to 350F only.
The FSM helps with other things to check but doesn't really walk you through bench syncing carbs.
Basically I followed directions, mounted carbs, bike idled super high. No air leaks. This was more tinkering around than final, I still need to do cam chain check, timing check and valve clearances but in the meantime...
The 1/8" drill bit vs. 1mm factory height thing concerns me - where is it stated the slide should be 1mm high (and thus 1/8" = 3mm drill bit would set the slides too high)?  I concur the may be the case for the CB350F as it caused my bike to have a very high idle even with no contact on the throttle adjustment bolt until I eventually lowered the slides with it ON the bike 1.5 turns in (down).  This of course wrecked my "close" bench sync and now I'm in no man's land and need to pull the carbs and restart.
However, I also came across another step in another thread where you should start the sync process by touching the throttle bolt to the tang, then turning it in 1 full rotation.  I did not do this, I had no contact on the tang until I mounted the carbs and then set it to just touching the tang.  Could that be the issue?
« Last Edit: April 09, 2021, 11:40:42 AM by bhh1989 »
Offline caluser2000
« Reply #15 on: April 09, 2021, 12:10:34 PM »
Any small drill bit will be fine. The important bit is all the slides are set at the same height and move up and down simultaneously.
« Last Edit: April 09, 2021, 12:15:15 PM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #16 on: April 09, 2021, 12:50:16 PM »
Go to sohc.co.uk
Go to tricks and tips
Go to page 2
7th down is a how to i wroteand 1/8 is way too big you need 1/16 or smaller ( 1mm or even less)
Offline bhh1989
« Reply #17 on: April 09, 2021, 01:03:49 PM »
Go to sohc.co.uk
Go to page 2
Awesome stuff, thank you.  I saw a video where a guy used a WD-40 straw.  I am going to measure that and see if it's about right.
« Reply #18 on: April 09, 2021, 05:01:38 PM »
Too flexible, you need something that cant be crushed
Offline Deltarider
« Reply #19 on: April 09, 2021, 11:59:49 PM »
Just peeked at 'Tricks and Tips' and I'm pleased to see Bryan suggests the same approach, I've practiced on my CB500, knowing: engine side. I've used a small allen key's long leg as a feeler gauge. You have to concentrate though and take your time. I've done it three times. When checked afterwards with a vac gauge set, it turned out I had managed to limit the difference within 2 cm Hg, which is well within factory specs. Some use steel balls to achieve a sync, by pursuing a simultaneous drop of the balls. I haven't tried that. It will be time consuming I guess, but should work.
« Last Edit: April 10, 2021, 01:02:22 AM by Deltarider »
CB500K2-ED Excel black
Offline bhh1989
« Reply #20 on: April 12, 2021, 03:53:32 AM »
I didn't see these replies until after redoing the bench sync with a WD-40 straw...  It measured 2mm in diameter, so I ran in the idle adjustment screw a little more to compensate then brought it back in to the full turn afterward.  Dialed it in, checked over and over the clearances with both no and full throttle and was pleased.  You definitely need to move the slides up and down after each minute adjustment and then check again - super easy to be off after tightening when talking about 1mm. I also set cam chain tensioner and valve clearances while carbs were off.
It absolutely purrs now.  Just a tiny blip of the starter when cold, no choke, and it starts and idles smoothly.  Still needs vacuum syncing (tiny tiny bit of hanging throttle once warm) but I am very happy with how the bench sync turned out.
Thanks folks!
