Author Topic: What else to do when resealing top end?  (Read 825 times)
Offline ReedNTX
« on: April 03, 2018, 06:09:48 PM »
Getting ready to do a reseal on the top end following the "leak free top end" thread pending being able to get ahold of one of 754's weldless kits.
Will be doing a shift cover gasket, starter clutch rebuild, and oil pan gasket as well. Any other things you would recommend to do/check while things are apart?
Bike is a 78 CB750F of unknown history, but with solid compression and oil pressure, and new looking valve train from what I could see with the valve cover partially off.
Re: What else to do when resealing top end?
« Reply #1 on: April 03, 2018, 07:05:50 PM »
Maybe get a set of new rubber "pucks" for underneath the cam bearings (rocker towers). You can get the right ones from PartsNmore. This is the #1 cause of oil leaks on these engines, due mostly to age and the years hardening them.
Did you also remove the head? If so, you will need a pair of 2.62x10.77 O-rings (Parker #111) to seal the 2 oil passages at the back of the cylinders, at the head. The standard 2.5x12 or 2.5x12 O-rings will not seal with today's head gaskets, because they are all thicker than OEM.
Offline ReedNTX
« Reply #2 on: April 03, 2018, 07:24:25 PM »
Thanks for the quick reply. I have not yet taken it apart, as I am waiting to get my hands on a frame kit.
There is a steady drip that I believe to be a puck- it is coming from the fins just above cylinder 1 exhaust, and another that looks to be a head gasket coming from the left front corner of the head to cylinder mating area.
What is the correct thickness for the pucks? I remember reading that many folks were getting sets that were too thin.
I will have to double check the o ring measurements. I ordered a complete overhaul gasket set rather than ordering them piece by piece.
