Author Topic: 71 cb500 K0 Powder Coat  (Read 2331 times)
Offline Fezzler
« on: April 04, 2018, 12:41:35 PM »
Powder coat done.  Next.  Forks and wheels.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: 71 cb500 K0 Powder Coat
« Reply #1 on: April 04, 2018, 01:07:03 PM »
+1 Looks good!
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Fezzler
« Reply #2 on: April 04, 2018, 02:16:18 PM »
Fezz - make sure you clean the powder coat completely off the inside, upper frame boss on the right side where the battery ground cable is installed. Any coating there can wreak havoc with your charging system later.
Thanks!  I was going to ask that.  Just scrape it off with a small chisel?
Also, on the cb500, I think there is a place near where the coils get installed that needs bare metal to ground correctly?  Did I see that in Ron's excellent assembly PDF?
After I delivered my frame to the powder coater, I came across a reference to a "frame coil tab" or perhaps on parts list page 122, item #19, Ref. 50400-323-000, PROTECTOR, ignition coil wire.  I thought I recalled seeing it on my frame but didn't remove it.
It looked in pictures that on the cb500 K0 it was on the frame above the coils and should not be painted.  I asked them to remove, but I didn't get it back today.  (Or I imagined seeing it.)  Anyone familiar with that part on a 71 cb500 K0?
One thing about buying a parts bike, as opposed to one intact I'm learning, you become very familiar with the parts manual as many smaller pieces, nuts, bolts, washers, etc. are tossed in boxes.  Learning to hunt, measure, identify.
Offline Paintedseat
« Reply #3 on: April 04, 2018, 02:28:35 PM »
Use a razor blade to score the area you want to remove before you scrape it off. That way you won't risk chips.
« Reply #4 on: April 04, 2018, 02:45:19 PM »
A grinder works great if you can handle it.
Why isnt there a thread in Project Shop for this bike?
Offline DurangoCB
« Reply #5 on: April 04, 2018, 05:01:44 PM »
Yeah, what he said ^
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
Offline Yamahawk
« Reply #6 on: April 04, 2018, 06:35:11 PM »
Hehe... yeah... and don't forget to run a tap through all the threaded holes in your frame and triple tree where you will install bolts. This is important to remove the powder coat from those threads... you will thank yourself for doing so, or kick yourself for not doing so... ;)
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Scott S
« Reply #7 on: April 04, 2018, 07:25:52 PM »
 What's that antenna looking thing on the lower triple?
 Be sure to sand inside the holes where the fork tubes go....that thin coat of powder is enough to make it too tight to slip the forks through.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Fezzler
« Reply #8 on: April 04, 2018, 08:37:37 PM »
Great advice everyone, as always.  That antenna is a plug they didn't remove.  A few of them in there.
Offline Fezzler
« Reply #9 on: April 04, 2018, 08:39:27 PM »
Offline Little_Phil
« Reply #10 on: April 05, 2018, 01:47:33 AM »
And is the location of the handlebars in the top yoke (triple) coated? If you coat the clamps also it will make fitting bars tight. Not sure what your plans are but I think that it relied on the earth from bars through here for starter circuit.
Offline Fezzler
« Reply #11 on: April 05, 2018, 06:46:20 AM »
Good to know.  I'll attempt to verify the ground properties of the clamps.
« Reply #12 on: April 05, 2018, 06:52:44 AM »
I like this song better...
Offline Fezzler
« Reply #13 on: April 05, 2018, 07:21:44 AM »
