Author Topic: HM300 & 341 Long Mounting Bolt  (Read 1428 times)
Offline Johnie
« on: April 05, 2018, 12:20:29 PM »
So Honda wants $24 for one bolt. I think they are about 5 1/2 inches long. You guys just getting them at a hardware store? Got a PM into Benton...
« Last Edit: April 05, 2018, 12:40:38 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: HM300 & 341 Long Mounting Bolt
« Reply #1 on: April 05, 2018, 12:50:08 PM »
I got a set of NOS ones. They are fat shank, with I think reduces hex head and threads.
 To replicate them , sleeve a regular bolt.
« Reply #2 on: April 05, 2018, 02:31:50 PM »
$16.50 at Partzilla but they show only one in stock.
https://www.partzilla.com/product/honda/90146-300-020?gclid=Cj0KCQjwkpfWBRDZARIsAAfeXapWQeO_QmmSyKYlb-i4hdNz9gf5D_nUtUw2krexUV8iyjoPp8GIj8MaAgCeEALw_wcB
Bill prolly has some or start a thread in PArts Wanted [instead of tech]
Offline Johnie
« Reply #3 on: April 05, 2018, 03:41:23 PM »
Yah, sent Bill a PM, but will list it.
Oshkosh, WI  USA
« Reply #4 on: April 05, 2018, 09:26:15 PM »
These bolts fits the pipes very well. Wrong size and the pipes might rattle around on the bolt with chrome flaking off, rust, holes...
They holds the passenger pegs too. Thread is same as the rear sprocket bolt nut. (fine)
Go for Honda or Yamiya aftermarket that cost not much less.
Offline Johnie
« Reply #5 on: April 06, 2018, 06:01:29 AM »
Yamiya lists 2 different ones. Which one is it? They both look the same...
CB750K BOLT, PILLION STEP    Detail
Yamiya Number:M026
   22 (F-18.Exhaust muffler)
Manufactured by:YAMIYA
1,800 JPY
(16.81 USD)
Add:
Yamiya Number:M089
Manufactured by:HONDA
2,130 JPY
(19.89 USD)
Add:
Oshkosh, WI  USA
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: April 06, 2018, 08:49:36 AM »
I think they are the same bolt, one made by Yamiya, one by Honda.
I've found that Yamiya's parts are well made.
Steve
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Johnie
« Reply #7 on: April 06, 2018, 09:00:29 AM »
I found some Honda from member jtmarks. Bought from him before. Good seller.
Oshkosh, WI  USA
« Reply #8 on: April 06, 2018, 09:02:26 AM »
Yamiya has some products with much better price than Honda. Some are not much cheaper.
Same with the heat shields for the 4-4 exhaust. Yamiya's cost much less than Honda.
DSS bolt
https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_90146300020/
More needed to exhaust pipes
DSS sell the heat shields as a kit with the heat insulating washers and screws.
2 of this
https://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_144247/
« Last Edit: April 06, 2018, 09:07:05 AM by PeWe »
Offline Johnie
« Reply #9 on: April 06, 2018, 09:05:55 AM »
I pick up the heat insulating washers at my local hardware store for cheap. Luckily I have the screws from other projects. Good info PeWe.  Thanks...
Oshkosh, WI  USA
« Reply #10 on: April 06, 2018, 09:11:02 AM »
There is 2 part numbers for early bikes.
 The part number is with mine, but for some reason I did not use them when I put no number pipes on my sandcast, so I suspect they were for 300 or 341.
« Reply #11 on: April 06, 2018, 10:30:46 AM »
I use the Honda bolts since they did not cost much more and are Honda. Fits the Yamiya No numbers and Yamiya Lotus Root on my K6.
I have a new sets of Honda bolts that will fasten the No numbers pipes on my K2 build that is slow going.
