Author Topic: 300 vs 341  (Read 1523 times)
Offline beemerbum
300 vs 341
« on: April 05, 2018, 04:51:08 PM »
I am contemplating springing for a set of repops from DSS. The 300's with removable baffle are $1495. The 341's are $400 less. My bike is a K1 with a K4 motor so it won't be a true collector's item. I could afford either but would not like to throw away $. Any advice out there from anyone who had to make a similar decision? I would prefer a louder less restrictive exhaust. Is there $400 worth of sound quality from the 300. I am dedicated to 4 into 4, as the look of the four exhausts, in my mind, is the true essence of the SOHC 4.
Offline Johnie
Re: 300 vs 341
« Reply #1 on: April 05, 2018, 04:52:59 PM »
Go with the 300's...sound is best and turns heads...at least that is my humble opinion :)
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: 300 vs 341
« Reply #2 on: April 05, 2018, 06:58:51 PM »
 Get the 341's and cut down the baffles lol.
Re: 300 vs 341
« Reply #3 on: April 05, 2018, 09:19:19 PM »
300 (Yamiya no numbers) without baffles work really fine with bigger bore and more. 341 way too restrictive.
300 gave more rwhp on my bike than the even more open Yamiya Lotus Root pipes. The latter more torque and work with baffles too.
300 are the pipes.
Offline cooldrum
Re: 300 vs 341
« Reply #4 on: April 06, 2018, 06:15:32 AM »
I ride a K4 all stock with the 4 into 4.  If I desire more sound baffles can be removed or cut down.  If your motor is a  true K4 then the 341's are a good match if running stock carbs, air box etc.  That's how it came from the factory.  Just Saying.  Yes, I agree with you about the signature look of those four pipes.
Offline Progas
Re: 300 vs 341
« Reply #5 on: April 06, 2018, 06:37:51 AM »
The 300's are the only way to go!!
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
Re: 300 vs 341
« Reply #6 on: April 06, 2018, 06:43:30 AM »
My 71 came new with 341's.  I took the end plugs out in the day.  Trust me, you can hear me coming.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Re: 300 vs 341
« Reply #7 on: April 06, 2018, 07:01:39 AM »
+1 for the 341's....not worth the extra $$$$ for the 300's.  You'll be the only one [besides us] that knows the difference.
And you can do the Hondaman mod - drill 1/2" holes in the baffle...
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: 300 vs 341
« Reply #8 on: April 06, 2018, 08:46:32 AM »
I'll just throw my 200 yen in. I bought the "no number" Yamiya pipes, I think that's the same as 300's. They sound great, Yamiya sends the little sleeves to help line up the crossovers. The fit up was the only issue, it takes a little persuading.
I love the sound, it has that walking exhaust note at the back that is just unique.
I also wonder if the lack of interior baffling will help longevity by not trapping any moisture.
Also, and this may be true of all of them, I think they are coated with something on the inside.
I have a K3 and Hondaman said my head was a K2, build date was 11 of 72. The bike runs great, stock air box and carbs.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline dcalvert
Re: 300 vs 341
« Reply #9 on: April 06, 2018, 09:36:51 AM »
I Just received a set of 300 from DSS and have not installed them yet. I believe they are Yamiya no numbers as the box they come is has Japanese writing on it and Yamiya installation instructions inside.
Also shipped from PA to AZ with no shipping charges!
Hope to get my exhaust flange's back from the chrome guy today and start fitting them up this week end
dcalvert
Re: 300 vs 341
« Reply #10 on: April 06, 2018, 10:20:11 AM »
Removed baffles and checked them inside so all are of correct and same model?
I got one HM300 replica pipe when I ordered the lotus root pipes. Found out when removing the baffles, 3 lotus root, one HM300. I got a replacement really quick.
My earlier order of HM300 (no numbers) were all correct
The 4-4 are tricky to mount first time if you have not done it before or long time ago. The front must be pressed on the head spigot as much as possible before the long rear bolt will fit thru both pipes and fit the frame. If front will glide out from the spigot, NEVER hammer, they will lock. Remove rear long bolt, let the go down a little and fron ca be pressed on as much as possible. In this position a strap around the pipes and cylinder+head can hold them until they are swinged up and the rear bolt with foot peg will fit.
No 2 pipe go on first, inside the side stand, then 1. Do not forget the rubber protections on 1, 2 for the side stand and center stand. there are small details that needs to be there.
DSS sell a new aftermarket center stand complete with everything. This is needed together with the 4-4 pipes
https://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_322054/
« Last Edit: April 06, 2018, 10:21:47 AM by PeWe »
Offline dcalvert
Re: 300 vs 341
« Reply #11 on: April 06, 2018, 10:44:29 AM »
Get tips PeWe keep them coming, I will be sure to take it slow and methodically. Can't wait to hear that 1971 Sound again.
dcalvert
Offline crazypj
  • I'm brill, me
Re: 300 vs 341
« Reply #12 on: April 06, 2018, 10:50:14 AM »
One 'good' thing about unleaded fuel, exhaust systems (and spark plugs) last much much longer without the chemical build up's from lead oxides
