Author Topic: 75 Honda CB550 K1 - Cylinders 2 & 3 dead  (Read 2770 times)
Offline Gene
  • Chat enuf you too can be a
« on: April 08, 2018, 05:01:54 PM »
Ok, I know this is not a new issue, just opening a thread to see where this dilemma leads me.
I have spark at the condensers (screwdriver check and v-meter), checked for spark at the #3 plug and nada. BUT, wildcard, I f***ed with my carbs - cleaned the bowls/jets/etc. after doing a REAL clean of the tank w/Prep-n-etch. Tank is, at last, clean. Been f**ckin around w/vinegar for years. AGAIN this is for those that come after me/us. I don't need hate.  ;D
Anyhoo - have yet to do a V check on the left coil (2 & 3) cuz I ran out of time. But, I will check that and report back here. Will also check fuel delivery, tho that doesn't seem like a likely culprit as 1 & 2 are fed off the same fuel line - still - will double-check.
Checked and rechecked points/timing - all looks right with the world. Will check again. Battery is fully charged - bike starts right up on 1 & 4 only. New plugs.
Throwing this out as a reminder to myself as well as a warning to others should they come across the same situation.
*1973 CB750K3 (Bow)
Re: 75 Honda CB550 K1 - Cylinders 2 & 3 dead
« Reply #1 on: April 08, 2018, 05:09:34 PM »
 See if you maybe did something to the wiring around the 2/3 coils while you were taking off and putting on the tank. Start the probing. Hope its something simple for ya.
« Reply #2 on: April 08, 2018, 07:18:49 PM »
 And clean  the points with paper.
 If you carefully open then with a screwdriver you can hear the plugs fire , if it's working.
 WARNING., IT CAN AT TIMES  BACKFIRE VERY LOUDLY..
Offline Gene
« Reply #3 on: April 09, 2018, 10:22:02 AM »
I thought of the tank on/off disconnection scenario this morning. Will check and report back. Has to be something that simple since all four were firing last week.
As always, thank you gents.
*1973 CB750K3 (Bow)
Offline Deltarider
  • I'm back
« Reply #4 on: April 09, 2018, 11:14:07 AM »
In case you have the stock ignition setup, I'd first check the 2.3 breakerpoints and condenser. Open the ignition cover. First check if 2.3 breakerpointgap is still correct and also that the forked connector at the back of the breakerpoints isn't accidently touching the plate. Then, with engine running, see if there's excessive arcing at the 2.3 breakerpoints. A tiny bit of sparking is normal, excessive sparking is not good. See
In this vid left condensor (1+4) is bad, right condensor (2+3) is good.
CB500K2-ED Excel black
Offline Gene
« Reply #5 on: April 09, 2018, 11:26:47 AM »
I did check that, thank you Delta. I was hoping it was the points and/or condenser. I think I'll replace both anyway - just to see what shakes.
But - 1 thing at a time.
*1973 CB750K3 (Bow)
« Reply #6 on: April 09, 2018, 11:44:35 AM »
Before you replace anything, it better to figure out what is wrong first.
Offline Gene
« Reply #7 on: April 09, 2018, 11:51:49 AM »
^^^ right. Just thinking out loud.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #8 on: April 09, 2018, 11:52:58 AM »
I'm getting it ready to sell - and I think it knows that. Sabotaging my efforts. He's very comfortable right where he is. Yes, I am anthropomorphizing a machine.
*1973 CB750K3 (Bow)
Offline Deltarider
  • I'm back
« Reply #9 on: April 09, 2018, 12:31:53 PM »
Try to think as your bike.
Offline Gene
« Reply #10 on: April 09, 2018, 02:17:56 PM »
Yes ;D ;D ;D
*1973 CB750K3 (Bow)
« Reply #11 on: April 10, 2018, 03:31:50 AM »
Bikes don't think.  They are merely machines.  Attributing human qualities to machinery is a good way to impede your understanding of said machinery.
Offline Gene
« Reply #12 on: April 10, 2018, 10:26:07 AM »
Fair enuf. If the bike had thoughts and feelings it would have bucked me off long ago.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #13 on: April 14, 2018, 01:44:25 PM »
Getting readings of 2 ohms on both coils at the B/W leads. They're connected well, which is too bad, that would have been a nice easy fix. still seeing the same issue. Checked for spark on #2 - same as 3, nothing. Plug grounded to the head, zero spark.
Battery fully charged. moving on. Checking cap resistance.
Then checking condensers.
in that order. reminding myself.
« Last Edit: April 14, 2018, 01:57:57 PM by Gene »
*1973 CB750K3 (Bow)
Offline Gene
« Reply #14 on: April 14, 2018, 01:49:16 PM »
MM set up pic for ohms - if I'm doing it wrong.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #15 on: April 14, 2018, 02:26:06 PM »
One cap tested out at 10+ (trash), the other was fine. I had two new ones anyway, tested, trimmed back a little wire, plugged 'em on, still no spark.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #16 on: April 14, 2018, 02:26:44 PM »
You want to check for voltage in B/W wires first. That way you kno the coil is firing.
Resistance check across caps after you confirm voltage.
OK - I did check for that earlier - 10.30 approx on both
Edit - 11.16 on both - battery needs another recharge
PS same plug in but at 20V on the MM.
« Last Edit: April 14, 2018, 02:30:25 PM by Gene »
*1973 CB750K3 (Bow)
Offline Gene
« Reply #17 on: April 14, 2018, 03:05:48 PM »
got to be the points . . . it's always the points. Back in a few/
« Last Edit: April 14, 2018, 03:08:19 PM by Gene »
*1973 CB750K3 (Bow)
Offline RJ CB450
« Reply #18 on: April 14, 2018, 03:33:12 PM »
This is off topic... Yes... Yes... But you never met my 'Tina.  That bike has enough personality to make even the most atheist believe is the Taoist belief that all things have a soul.
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
Offline Gene
« Reply #19 on: April 14, 2018, 05:24:11 PM »
it's always the points. gap was fine, etc. But, I'm a hoarder, so I threw the old points back on for 2-3. I had replaced them w/Da-f***in-ici (made in Japan, thought they were fine) a year or more ago. Put the old TEC points back on - bang. fired right up.
dang. Well, it's ready to go now. Always a pleasure gentlemen.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #20 on: April 14, 2018, 05:24:35 PM »
I believe you.
*1973 CB750K3 (Bow)
Offline Gene
« Reply #21 on: April 15, 2018, 05:46:00 PM »
what I wrote here previously was rude and not worthy of this forum, my apologies to any who read it and were offended.
Thank you all, even you, Cal ;), for your help with any and all issues arising from this amateur's lack of knowledge. I'm easily distracted by shiny things.
« Last Edit: April 16, 2018, 08:56:15 PM by Gene »
*1973 CB750K3 (Bow)
