Author Topic: cb550 adjustable cam sprocket  (Read 1470 times)
Offline ts354
« on: April 16, 2018, 12:12:37 PM »
I'm rebuilding my CB550 '74 engine.  I purchased an adjustable cam sprocket to replace my worn one. (I don't think the p.o. knew how to adjust the cam chain) So, in order to install and degree the cam, do you have to cut the hump off (the one that covers the cam sprocket) on the rocker cover?  If you do; how much does one need to cut off?  Do both cam sprocket bolts need to be accessed at the same time in order to degree the cam? - because if they do need to be accessed at the same time the sprocket is half buried into the head even with the hump cut off.  Just wondering if anyone has done this?
Thanks,
Todd
Offline flatlander
Re: cb550 adjustable cam sprocket
« Reply #1 on: April 16, 2018, 12:37:46 PM »
you can cut off the "hump" if you have a spare cover. if it's your only cover then i'd leave it on. a modified cover makes the process easier and quicker but you can still degree your cam with an intact cover, you'll just need to take it off to make adjustments, then install it again for measuring.
you access one sprocket bolt at a time, whichever is high enough. that means that when you make an adjustment, you loosen the top bolt while the one at the bottom still holds the sprocket in position, rotate the engine until the bolt that's still tightened emerges. then loosen that one, make your adjustment, tighten it, rotate engine, tighten second bolt... you get the idea?
if you ever remove sprocket bolts completely make sure you stuff a shop towel in the camchain tunnel in case you drop them. and before you torque them down for final installation, clean them and also then threads on the sprocket with some acetone, and use locktite.
Offline ts354
« Reply #2 on: April 16, 2018, 01:05:17 PM »
Thanks Flatlander,
Use NEW bolts as well??  It seems I have read where they are stretch-to-torque bolts and should not be re-used? Is that correct?
Todd
Offline flatlander
« Reply #3 on: April 16, 2018, 01:45:01 PM »
you can re-use them, at least i have done so if they were not damaged.
if you get new ones: suzuki bolts with part number 09103-07001 have a bit more meat on the flange which helps with a slotted sprocket.
Offline flatlander
« Reply #4 on: April 24, 2018, 03:08:24 AM »
hey did this work for you?
Offline ts354
« Reply #5 on: April 24, 2018, 06:35:07 AM »
I'm not ready to get at it yet, MRieck has my head and working on it.  But, I have looked on ebay for the bolts.  There are several out there, I just haven't pulled the trigger yet. :)
Offline flatlander
« Reply #6 on: April 24, 2018, 07:01:21 AM »
ok. must be tough reading and typing without a head with eyes in it to look through ;)
