Author Topic: Terry's Kawasaki ZZR1100 "Bring it back to life" project.  (Read 74973 times)
Offline spotty
Re: Terry's Kawasaki ZZR1100 "Bring it back to life" project.
« Reply #375 on: June 23, 2019, 10:11:57 PM »
i have a feeling they may have gone by mistake, fling me a pic and i'll diagnose the situation, i was missing one i was looking for y'day but i assumed it had just been eaten by the goblins that lurk in my dungeon ( either that or i've put it somewhere else )
i blame Terry
« Reply #376 on: June 23, 2019, 10:20:05 PM »
A friend has a Honda Super Blackbird 1997 without fairing. Other bar clamps for normal handle bar.
Look OK with stock exhaust. But he cannot use full speed since the wind is too strong from 220kph.
He checked the bike on Dyno, 133 on the wheel still home.
Offline spotty
« Reply #377 on: June 23, 2019, 10:30:56 PM »
yeah, i've clocked close on 250kmh on the vmax a few times ( on closed roads only of course officer ) and it is distinctly uncomfortable but at the same time .....what a hell of a thrill. at those speeds you're pulling a 100M every one and a half seconds
i blame Terry
« Reply #378 on: June 24, 2019, 12:37:11 AM »
No worries, will do. ;D
Offline spotty
« Reply #379 on: June 29, 2019, 01:50:15 AM »
Got the motor back together today,not too hard as Terry did most of the complicated stuff, just oil and water pumps them sump
Got the seat all cleaned and treated this week courtesy of the car detailing department at work
Found the headlight is screwed, little stone chip blew out inside , new one $200 local or $80 eBay UK
Also seemed like a good idea to put new sump plug washers on, one was ok, the other one not so much
« Last Edit: June 29, 2019, 01:53:39 AM by spotty »
i blame Terry
Offline spotty
« Reply #380 on: June 29, 2019, 01:56:29 AM »
Photos not behaving today
i blame Terry
Offline spotty
« Reply #381 on: June 29, 2019, 02:00:37 AM »
Tomorrow the plan is to derust, clean and paint the exhaust
And give all the oil pipes and such a clean and flush
And while I'm at it the rear wheel from the VMAX needs finishing and painting so I can get that back on its wheels and off the bike lift so the big ZZR can go on the lift to start putting back together
i blame Terry
« Reply #382 on: June 29, 2019, 03:44:48 AM »
Good work Spotty, looks great! ;D
Offline spotty
« Reply #383 on: June 30, 2019, 03:11:04 AM »
Well today was a productive sort of the thing, checked the cam timing after a suggest by Terry, all seemed well,
Reinstalled the water pump to cylinder pipework after a clean up and repaint of the metal pipe bit
Took the rear peg/ exhaust mounts apart for a clean and refurb, got them looking much better
Derusted the pipes ready to repaint later in the week
i blame Terry
Offline spotty
« Reply #384 on: June 30, 2019, 03:23:22 AM »
#$%*e forum is bollocking up every post I do, photos not coming through
Try sgain
i blame Terry
Offline spotty
« Reply #385 on: June 30, 2019, 03:29:59 AM »
Maybe more beer is the answer
Have been using a nylon wheel on my mini grinder to remove crap/corrosion from parts
It's soft enough that it doesn't remove any metal but tough enough to get rid of dirt and corrosion.
Check before and after of alloy footpegs
i blame Terry
« Reply #386 on: June 30, 2019, 01:10:38 PM »
Was there a "Before" pic Spotty? Anyway, fantastic work mate, good to see your mojo is back too! ;D
« Reply #387 on: June 30, 2019, 01:15:23 PM »
Before is the left one which is dull and somewhat tarnished, whereas the right one is in its freshly brushed goodness.  Are you using a pink or blue nylon string wheel Spotty?
Good looking work!
You must want to be riding the beast or the project excitement has you motivated.
David
Offline jgger
« Reply #388 on: June 30, 2019, 01:36:02 PM »
Really Terry, you know how to hurt a guy!😢  Here in SoCal we have a saying "Abierto Los ojos" open your eyes.😁
Or even Stevie Wonder could see that. 🙈🙉🙊
« Last Edit: June 30, 2019, 01:37:39 PM by jgger »
Offline spotty
« Reply #389 on: June 30, 2019, 03:07:22 PM »
Good looking work!
David
well spotted, maybe terrys eyes are going along with his waistline
using these
https://www.ebay.com.au/itm/10pcs-75mm-Nylon-Fiber-Round-Abrasive-Polishing-Buffing-Wheel-Disc-Buffing-Pad/182255048582?hash=item2a6f3f5786&_trkparms=ispr%3D1&enc=AQADAAADEFjVrDbVsZ8oH%2F8PNHtt9VX4%2Fw7FZcmMuqsX8uaFEduVLSc1Kjlsc7TcVRhXgwLvHsF06m7QNjlyHYcJYZ9FRVLMnF%2FZkeKQ%2FR9ErBI1opkalpVFEGnGld7GmWpimwNsksDid7QQnzHgkYrTifZKrYLR%2BbYaanpe73C9C4mXgllmMLIqXaD8gz5ta9fE5W%2Bf39UinANWR%2FCX%2FxqGNt6iSq3DG6Oc4ZdIkkOPWY9eS%2BlwqVbJ4wWMKYoKiENNuNpcBM9zXGXd3y%2BWmTi5B1Xxn1lwjtKL4cAS4ZG2ul3fuO1X0VNpqfPl1F%2BptBY3I28WsETf5fDHQ8YmKDKuxG3aJeGumHKyiFOMMcJy5v2MHObLRrGsagiYTHIW%2BUN%2BMSMeqLsxjee72jQbhNwY3bnasYb6R070GHT6ua4Q5h%2FQE86LQySMOUkg0nhg5ii5HW1RJ2ljKDEnPh0fVc1pDaCzfG7vhbwddVPc7A4ZL3jb1rMVS%2FlL570VLig9YUc8CfQJ4sdv9L4bqO8rKX%2FUk51JWV3l%2FbKfrcQCoTqaQmIzsjX%2BFd9sz%2B74QvNrR8cMUU6SvxpcoqZ1HU%2BkqMeO541JxZLZPwu%2BtoUHRnjJDySeyhY%2BNffMmfyn6GECSLiNoJh%2FbJYbZmmMgxaOGpbABVCXX2TdU7SaJJS0HeLUlx4EQ62ygzx8wzvSb3VfBAeYKJ3mSraVfF8YgjTlPsUYJG64QIPxH6pjrJaigTNL2a4ENyhLmQi7dHMbA3NqTXcoyimeUK4tbHVWwIHUE%2Fy7umzyGbMRsYaIVjrN6oC0YZkD8%2B0PGPisToxKgwqkfeq3WHM64ptbEpOcD8%2BQGCqoYKdUHUliAaVkYNsBLc3nl6onQuYigz%2Ftn9bjtok%2FrDEjHRlLIQ%2FJ3kzgY0NMM1ku610j%2F%2FoVQY20zlaPlRdI%2F65EtjAnyhD95gzYrroDS3tN4Tfy9qjgdum42DohVKhfdl48h%2FOFzPgX7sV2dpyBW7nz88lRrtqhrTPKHCba6RpmnfdklAtfTZanlYTm25o46VIVWY0%3D&checksum=1822550485827dcb204668774e67a2d61473fd255296&frcectupt=true
thats got to be the longest ebay link i've ever seen
they wear away pretty quick but do a lovely job
i blame Terry
« Reply #390 on: July 01, 2019, 03:16:53 AM »
Ha ha, sorry about that, I was looking at the pic on the tiny screen of my iPhone 5, now I'm looking at the "big screen" I can see the difference right away. ;D
Offline spotty
« Reply #391 on: July 04, 2019, 12:10:59 AM »
Had a most pleasant day, forgot to go to work, took the dogs for a nice walk, then got stuck into some zzr'ing
Pressure washed the bike and all the bodywork, stripped a the little bits of fairing off the big bits and put them through the dishwasher
Painted the headers on the exhaust ( did them in potbelly spray paint in charcoal metallic just to be different)  and will polish the chrome mufflers when they're dry enough to handle
Built a proper work bench out in the carport so I don't have to keep carrying stuff up to the under-house dungeon to do stuff
Painted the vmax back wheel so I can get it off the bike lift and get the zzr on there, just got to put the rim stripes on to match the front and slap the new bearings in as soon as the paint is dry ( and out the disc back on and reassemble the drive side where the shaft/diff stuff attached )
Having had a closer look at the zzr I might end up pulling the swingarm to check bearings and give a proper clean and repaint. Also rear caliper seems to be dragging so that may need new seals
Front end needs new seals anyway so while that's out, check steering head and wheel bearings and repaint sliders
Frame needs a couple of touch-ups and the fairing has some issues with cracking and a couple of tabs broken off
And the new headlight
And change the 4 piston front calipers for 6 piston ones
And possibly investigate a superbike bar conversion, it's only about $125 and works with the fairing still on
And tyres...
And...
And....
In the meantime it's beer o'clock
Also yesterday I asked one of the car detailers at work if I could bring in a jar and scrounge some autosol ( I would buy it but Matt Black paint is cheaper ), he gave me a half full kilo tin,
Should last me about 3 lifetimes.......
Now try and post and see how many pics it'll let me do today
i blame Terry
Offline spotty
« Reply #392 on: July 04, 2019, 12:14:40 AM »
Apparently none.......
Maybe tomorrow,
i blame Terry
« Reply #393 on: July 04, 2019, 12:50:55 AM »
Woohoo! Looks great Spotty, and even more naked-er than I remember! It looks like the project swap has given you a new lease on life! Don't take too many dodgy days off work though, that might piss someone off, whose not as keen on ZZR's as you. ;D
« Reply #394 on: July 04, 2019, 12:15:30 PM »
A roller! Engine soon ready too, right?
Terry let boxes with spareparts follow the bike? Bottles with bolting and forgetting-issues-juice.
Offline spotty
« Reply #395 on: July 04, 2019, 03:04:52 PM »
engine in one piece now
the idea is to reduce the amount of parts in the plastic tubs instead of adding to them
gotta try and restrain myself from over thinking it and getting too detailed, otherwise i'll end up stripping it right down , just get it clean and safe then registered
then maybe i can give the vmax some loving that its sort of missed out on for a couple of years while i've tried to keep it on the road
i blame Terry
Offline spotty
« Reply #396 on: July 05, 2019, 01:48:14 AM »
The weekends Todo list.....
Assuming I can avoid gardening duties
i blame Terry
« Reply #397 on: July 05, 2019, 03:16:23 PM »
Now that's what I call organised! I'll be back in Melbourne around lunch time, so hopefully I'll get a couple of hours of spanner Twirling on the Swamp Rat in before it gets dark. I wish I had a pen and notebook now, so I could write a "to do" list on my boring 5 hour flight home..... ;D
Offline spotty
« Reply #398 on: July 05, 2019, 03:34:06 PM »
I believe the young folk these days have some sort of 'app' inside their telephonic devices that allows them to electronically make such lists
 ( and then of course share them on the relevant social media platforms )
i blame Terry
Offline spotty
« Reply #399 on: July 05, 2019, 03:41:18 PM »
A quick try to get some pics up from the other days activities
It appears that due to some anomaly or other I can only post one pic at a time which is pissing me off
i blame Terry
