Author Topic: Terry's Kawasaki ZZR1100 "Bring it back to life" project.  (Read 77452 times)
Offline bear
  • Leeton in Australia
Re: Terry's Kawasaki ZZR1100 "Bring it back to life" project.
« Reply #550 on: April 30, 2020, 04:58:15 AM »
Thanks Spot, I've ordered one myself.
Offline spotty
« Reply #551 on: April 30, 2020, 06:20:12 AM »
The things I noticed were
Connect the clear pipe direct to the bleed screw, don't use the little black thing that will be stuck in the end of the clear pipe when it turns up
Open the bleed screw further than you would I'd you were just hand bleeding, probably a full turn
My compressor refill kicks in at about 50psi and it didn't seem to draw the fluid too well below that. So as soon as the compressor kicks off on the refill I've been stopping and waiting till it gets back up to full pressure
Keep a close eye on the fluid level in the mc, mine was nearly emptying with each "suck"
« Last Edit: April 30, 2020, 06:23:27 AM by spotty »
i blame Terry
Offline grcamna2
« Reply #552 on: May 04, 2020, 09:25:24 AM »
subscribed  8)
« Reply #553 on: May 04, 2020, 04:14:59 PM »
My brake bleeder arrived yesterday, I didn't have any problems bleeding the brakes on the Max bike, so I won't use the bleeder on the FJR1300/GSXR1000 brake combo, but if I have any problems I'll whip it out! ;D
Offline spotty
« Reply #554 on: June 29, 2020, 03:27:42 AM »
Today was an unallocated activity day so got down and dirty with the zzr
Ever since I got the new tank from Italy I've not been able to see how it mounted, today I used logic and lined up the wear marks from the isolating rubbers, the rear bolt holes and ....aha, the front mount doesn't line up, must have got a knock in transit, a few gentle persuasive taps with a number 4 hammer and success, one job done
Next, mix up some coolant 50/50 with water and started pouring it in the filler neck, then ran to get a bucket to catch it as it ran out the bottom of the motor. Let it drain out, replaced the O ring and did up the retaining bolt properly and no leak, another job done
Next fill up the shiny new battery with acid , only  problem was it doesn't actually fit in the battery box.....bollocks. minor recompense is it fits the satanic Hyosung that I'm trying to sort for a mate. So job 3 turns out to be sorting another battery rather than fitting the one I've had on the shelf for months
Soooo, next was at least get some oil into it, however it seems that the oil I thought I'd had on the shelf with the battery was actually car oil so there's job number 4, get some proper oil
So, two out of four jobs done, which for me is not a bad average at all
i blame Terry
Offline spotty
« Reply #555 on: June 29, 2020, 03:30:27 AM »
Happy tankday
i blame Terry
« Reply #556 on: June 29, 2020, 04:13:51 AM »
Well done Spotty, I'm trying to work out why there's such a large gap betwixt frame and tank, I don't remember it being so with the old tank? But then again, I'm very old, and don't remember what I had for breakfast, so I'm sure it's not an issue, just looks odd? And what's wrong with car oil? I've never bought bike specific oil, although I may with the 1428 build because I've thrown so much money into it, another 50 or 60 bucks for some fancy bike specific oil won't make much difference, to my already melted credit card? ;D
Offline spotty
« Reply #557 on: June 29, 2020, 05:55:24 AM »
There's a whole load of plastic that fills in those gaps and then a whole load more that goes on the outside
I'm not sure about the oil but some have friction modifiers that will cause terminal clutch slip, I had planned on buying Kmart oil to start it up, then do an immediate oil and filter change with something decent but the stuff on the shelf is a reasonably flash Renault oil and I'm not sure if it's safe to use
And for once.......better safe than sorry ( or putting a new clutch in )
i blame Terry
Offline grcamna2
« Reply #558 on: June 30, 2020, 12:34:18 AM »
I think when the automotive oil has "Energy Conserving",etc. written on the container that it has friction modifiers that will impregnate your fiber clutch friction plates and they will continue to slip after that..
Do you have Shell Rotella T4 15/40wt truck oil over there ? The back of the container gives one of the safe additives for wet clutches as: Jaso Ma/MA2.I run that oil.
Offline spotty
« Reply #559 on: July 10, 2020, 04:32:06 PM »
Finally with the help of my mate Jules got the throttle to return all on its own, got it to do so by relaxing every bit of adjustment on both cables
Why this would be the cure is beyond me, but it works. It has left an annoying bit of looseness in the throttle grip but probably no more than is recommended in the book, I just like no slop in the take-up
Also introduced oil to the engine, then while trying to work out how to prime the oil pump, let it all out again, then out it all back in again
I may have to borrow the electric roll starter from whoever has it at the moment to prime the oil before start up day
Took the back wheel out to bodge up repairs on the cush drive ( slices of push bike inner tube around the metal towers to take up the slop )
This is the recommended method of repair on the zzr sites, you can of course replace the rubber parts but they don't last long and this bodge works better
So walk the dogs, drop the chainsaw off for repairs and hopefully a day of bike fixing today
i blame Terry
« Reply #560 on: July 10, 2020, 05:01:36 PM »
Good job Spotty, did you remove all the skin, tissue and blood from your chainsaw before you took it to the shop? ;D
Offline spotty
« Reply #561 on: July 10, 2020, 09:43:44 PM »
No need, the guy in there is well used to it and offers free tips on how to avoid cuddling up to the spinning chain
And as you'll have noticed the weather is #$%*e so I'm having a day in playing in the kitchen
So far -
Habanero and coriander seed bread
Coon cheese ( say it while you still can ), jalapenos and coriander leaf bread
Pickled onions in black vinegar
Pickled cabbage with mustard seed
Pickled cabbage with Cummin seed
Pickled cabbage with habanero
Pickled carrots with caraway seed
i blame Terry
Offline grcamna2
« Reply #562 on: July 11, 2020, 12:16:51 AM »
So far -
What dish are you preparing  :) ?
« Reply #563 on: July 11, 2020, 12:59:06 AM »
Sounds magnificent Spotty, I'll have a jar of each, please? We can use the term "Coon" cheese, because the company was named after the man who created the brand, who's surname was "Coon". (Edward William Coon) Our "white folks are all racist" over-educated but not particularly intelligent PC Police went after the cheese company years ago to have the name banned, only to find that it was named after a guy who was a "Coon" by name. Looks like they're gonna try again, who knows? Maybe some politician will decide that Eddie Coon's surname is racist? God help us........... ;D
Offline grcamna2
« Reply #564 on: July 11, 2020, 01:07:34 AM »
Lol  :D
« Reply #565 on: July 11, 2020, 04:54:34 AM »
Please, we have a BLM leader here in the states trying to defund the police inher city as well as defundomg the US Military abroad! If these idiots will tear down Abraham Lincoln's monuments/statues and those whom were instrumental in ending slavery in the US then a name is nothing to them.
We need to ship the lot of them all to outer space since everyone everywhere here has done something to offend them. Bunch of twits!.
« Reply #566 on: July 11, 2020, 05:41:41 PM »
Yep, interestingly there is a theory (supported by some leaked Chinese Communist Party documents and emails and PM's in the US between various left wing organisations) that the riots were encouraged, and in some cases financed, by the CCP. The Chinese news services were having a propaganda field day with reports that America was imploding from within, that there was no law and order, that the POTA was hiding in his bunker under the White House while America burned, etc etc. Why? Supposedly to distract folks from the Corona Virus and the repression of freedom of the people in Hong Kong, and the world pointing their fingers at China. Interesting times. ;D
Offline grcamna2
« Reply #567 on: July 11, 2020, 05:56:17 PM »
I wouldn't be surprised..  ::)
Offline bear
« Reply #568 on: July 11, 2020, 06:20:06 PM »
God save me from the "loony lefties", the " radical rights", the PC zealot's and the world's conspiracy theorists that struggle with their ever tightening tinfoil hats.
We can all reach into the www and pull out any sudo fact that support our views.
Me? I'm gunna stick to talking #$%* about motor bikes and taking the piss whenever I get the opportunity. ;D
Brian
Offline spotty
« Reply #569 on: July 11, 2020, 06:20:44 PM »
One bodged cush drive, one slice of bicycle inner tube on each post and no slop in the back wheel, woohoo
And the breads turned out lovely though the habanero bread could have been hotter, use more actual chillies next time, probably with cheese as well
Anyway, off to put some more zzr11 together, and find somewhere to store the bicycle parts where no-one will see them and accuse me of being one of the Lycra locust crew, that's worse than someone thinking you ride a scooter
Bicycles - under 18 or over 05 - no other excuse
i blame Terry
Offline spotty
« Reply #570 on: July 11, 2020, 10:45:57 PM »
Made a spacer from a large washer so the bar ends wouldn't bind on the throttle tube/grip, even painted it black so it wouldn't be obvious
i blame Terry
Offline spotty
« Reply #571 on: July 11, 2020, 10:49:47 PM »
Put the shiny new  petrol cap on the bright green tank using blue anodised bolts, looks lovely.....
Eventually the tank will get painted and the bolts will be replaced with green or black or silver
i blame Terry
Offline spotty
« Reply #572 on: July 11, 2020, 10:58:02 PM »
And last post for the day....
I hate electrics, after much thought and study of the wiring diagram I finally worked out that the starter motor wasn't connected and neither was the clutch cut out switch
So attended to those and..... nothing
I get the idiot lights coming on, however they are brighter when the kill switch is in the OFF position, when the switch is turned to ON then the lights dim and the tacho turns round to 3K
Indicators work sometimes and the headlight doesn't seem to want to glow in the slightest
Horns work
When the ignition key is turned on the fuel pump does nothing
I hate electrics
i blame Terry
« Reply #573 on: July 11, 2020, 11:13:46 PM »
Brian
Amen, brother Bear. 8)
Offline grcamna2
« Reply #574 on: July 12, 2020, 12:22:40 AM »
To myself,looks good to go.
