Author Topic: 2013 harley. What would cause this?  (Read 1633 times)
Offline Prospect
« on: April 25, 2018, 11:10:56 AM »
This is my brothers bike. The battery is 2.5 years old and plugged into a trickle charger over the winter. This week we found the fuse to the trickle charger pig tail blown and this build up on the negative battery terminal. When o took the picture we had already removed a lot of the build up.
Any ideas?
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline FuZZie
Re: 2013 harley. What would cause this?
« Reply #1 on: April 25, 2018, 05:18:35 PM »
Lead corrosion, usually from battery acid.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #2 on: April 25, 2018, 06:46:57 PM »
If the charger is a trickle charger (low amp, but constant charge), the battery may have been overcharged forcing the acid up through the terminal and causing the corrosion to build on the combination of lead terminal and copper wire connection. The battery may be OK after cleanng the corrosion, or it may have been damaged by being over charged.
.........Paul
Offline BPellerine
« Reply #3 on: April 25, 2018, 07:06:04 PM »
used a trickle charger on my harley battery last winter,the battery was ruined come spring,now I take it out and store it inside,charging it every month or so,this has always worked for me.
1978 CB 750K ard and webers
another anfob
Offline jgger
« Reply #4 on: April 25, 2018, 07:58:08 PM »
I'm thinking that if the battery can't vent while charging it would also help  cause this. If it has removable caps, were they open/removed?
Offline FuZZie
« Reply #5 on: April 26, 2018, 04:02:30 AM »
.........Paul
That's a good point. If the battery is still good and you use it keep an eye on it for future leakage.
Offline RJ CB450
« Reply #6 on: April 26, 2018, 07:47:14 AM »
I had a sort of similar in my battery for my 15.  Cooked a cell, though I had accidentally let the battery discharge cause initially didnt plug charger in.  The ones with auto sense shutoff best
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
Offline Prospect
« Reply #7 on: April 27, 2018, 05:29:26 PM »
Thanks for the replies.  I don't believe this battery is vented so I guess it's venting through the negative terminal.  We cleaned it all and it seems to take a charge for now.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: May 01, 2018, 07:37:44 PM »
Copper terminal (you can see it peeking through the corrosion). My wife's car does the same thing.
