Author Topic: A slow Seeley Turbo build  (Read 9271 times)
Offline spotty
Re: A slow Seeley Turbo build
« Reply #25 on: May 23, 2018, 04:18:25 PM »
that can only be described as severely trouser tightening, keep it up, this is better than porn
i blame Terry
Offline Zunspec
« Reply #26 on: May 24, 2018, 04:26:26 AM »
I have trouble adjusting the tappets :-[  Very nice work eli  8)
Cheers  Geoff
Offline eli
  • Life is hard if you cannot work on your bike...
    • Seeley-Honda
« Reply #27 on: May 24, 2018, 02:07:15 PM »
Thanks, guys. But you notice that the finish is far from perfect?  ;D
Actually I'm thinking about leaving all the aluminum parts raw, with welds and scratches and everything. Polishing is such a tiring job, I hate it! At the moment, I like the rough looks...
« Last Edit: May 24, 2018, 02:17:32 PM by eli »
Will my patience hold till the thing is finished???
Seeley build:
http://forums.sohc4.net/index.php/topic,171911.0.html
« Reply #28 on: May 24, 2018, 08:04:46 PM »
If the grooves are rough , easy fix.
 When milling, make a light climb cut both ways.
 That is move it a few thou, cut then move over the other way , just taking less than .1mm for finishing.
 Climb cutting, work is moving same direction as the cutter.. the cutter is trying to climb into the work.
 Great job on the sump.
Offline eli
    • Seeley-Honda
« Reply #29 on: May 25, 2018, 01:44:46 AM »
Frank, I will try that! There again you can see that I'm no professional. Sadly, I have no one around who is a professional and could show me a trick or two. There is nothing better but experience. Please feel free to criticise what I do or suggest tricks, OK?
By the way, the rough surface of the sump should help transfering heat, shouldn't it?
Seeley build:
Offline newday777
« Reply #30 on: April 18, 2022, 07:53:44 PM »
Any updates? I see your last post on this was 2018....
Stu
My current rides
Prior bikes....
« Reply #31 on: April 20, 2022, 11:29:19 AM »
 Eli was last on Dec. 22, a PM might work.
Offline newday777
« Reply #32 on: April 29, 2022, 05:24:41 AM »
Thanks, I did get in touch with him. No progress on the Seeley as yet......
Stu
My current rides
Prior bikes....
