Author Topic: Tail Lamp Lens Removal  (Read 1258 times)
Offline BRG-BIRD
« on: May 03, 2018, 08:25:02 PM »
Hi all
I have a 75 CB550 with a burnt out brake light bulb. For the life on me I cannot remove the lens without destroying the lens. Yes I have removed the four fasteners helping to hold it on. What am I doing wrong?
Thank you
Mark
“You are either on something or onto something.” The Comman Man
Offline SF
  • I burn gas very well
Re: Tail Lamp Lens Removal
« Reply #1 on: May 04, 2018, 03:34:22 AM »
It’s probably stuck on from a gasket
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Kevin D
  • SE Michigan
« Reply #2 on: May 04, 2018, 04:41:27 AM »
Spray some wd40 around the perimeter and let it soak for a bit.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #3 on: May 04, 2018, 07:13:14 AM »
^^+1 most likely the 40-year old gasket, or maybe some PO shenanigans.
Heat, and a butter knife, under the edge....
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: May 04, 2018, 01:02:31 PM »
Yep, they stick badly. Be careful, I have cracked more than one trying to pry it off.
Offline BRG-BIRD
« Reply #5 on: May 04, 2018, 07:49:39 PM »
PO shenanigans or @ss clown at work. Got it off without damage thanks to folks recommending a solvent to soften the nonfactory sealant used to secure the lens. :)
Offline SF
« Reply #6 on: May 04, 2018, 09:23:47 PM »
Now put the lens in the top rack of the dish washer to clean er up
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline Phinn
  • Subversive
« Reply #7 on: May 05, 2018, 11:49:06 AM »
Sealant? On a plastic lens?
I don’t understand people sometimes.
1978 CB750K -- "Mouse," a former basket case, resurrected
