Author Topic: Sticky Throttle???  (Read 819 times)
Offline SOHCiro
  • Shi* happens when you least expect it
Sticky Throttle???
« on: May 05, 2018, 01:43:09 AM »
Recently replaced my gummed up throttle cable with brand new ones, lubed both push& pull cables really well.
When the motor is off, throttle feels so light and returns crisp like a champ!!
But...When the motor is running, up to about 1/8 to 1/4 turn, throttle doesn't return  :-\
I played around with the cable free play and I found it to be "least sticky" at almost zero play.
I felt like maybe it's the shaft spring so I even sprayed some lube on it too but nothing changes.
Any ideas??
76' 750F SuperSport
Re: Sticky Throttle???
« Reply #1 on: May 05, 2018, 03:36:04 AM »
pull the tube off the bars,clean dry and use graphite powder,ya just gotta find a balance between the push pull set up.
Offline SOHCiro
« Reply #2 on: May 05, 2018, 02:42:55 PM »
Never tried graphite powder lubes, will give it a shot! thanks
76' 750F SuperSport
