Author Topic: 1973 750 oil drip  (Read 1656 times)
Offline Handlebar
1973 750 oil drip
« on: May 06, 2018, 06:34:36 PM »
I have been working on my 73. I have noticed a oil drip on the left side , it is not the shift seal, and i suspect it is the oil seal behind the sprocket . Question is can this be replaced as it sets.
Re: 1973 750 oil drip
« Reply #1 on: May 06, 2018, 07:08:16 PM »
has it got an auto chain lube?
« Reply #2 on: May 07, 2018, 05:28:23 AM »
 Check around the neutral switch under the engine on that side also. I had one that was a pretty good leaker. It was not even the gasket but was coming through the body of the switch.Easy fix.
« Reply #3 on: May 07, 2018, 05:59:25 AM »
Yes, the seal behind the sprocket can be replaced.  To get the old one out, drive two screws in it and pull it.  The new one goes back in with a - very - light use of silicon to make sure it stays.
But, as other say, first check where is it really coming from.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: May 07, 2018, 08:22:14 AM »
What is the fix? I think I might have this going on...
--Evan
1975 CB750K "Rhonda"
« Reply #5 on: May 07, 2018, 08:37:16 AM »
Replace the switch  ;)
Offline evanphi
  • Apparently I'm an
« Reply #6 on: May 07, 2018, 08:37:51 AM »
Figured it was that easy. :P
--Evan
Offline adamalk3
« Reply #7 on: May 07, 2018, 09:50:03 AM »
+1 on the chain luber.
« Reply #8 on: May 07, 2018, 01:01:24 PM »
also do a really good clean under the sprocket cover...very common for the case to be cracked in there
Offline Handlebar
« Reply #9 on: May 07, 2018, 05:51:59 PM »
Thanks for the input. It is not equipped with the "auto lube" system,must of been a option. I am waiting on rear shoes,then the "ass end" comes apart. I will look things over then. Hopefully it is not a cracked case as SeanBarney experienced .
« Reply #10 on: May 08, 2018, 04:18:48 AM »
 All the K3's came with an oiler from the factory. Maybe someone changed it out with a plug ? They stopped in either 75 or 76, can't remember right now. Here is a picture of one-  https://www.ebay.com/itm/74-HONDA-CB750-SOHC-CB-750-HM369B-ENGINE-SPROCKET-CHAIN-OILER-GREASER/351681063053?hash=item51e1d3288d:g:KS8AAOSwYlJW3zk8&vxp=mtr
Offline Handlebar
« Reply #11 on: May 23, 2018, 06:05:40 PM »
Well i found the culpit, Small dime sized chain slap on the case, Pieces still intact 3 coats of JB weld and wala no more oil drip. Installed the 4into2 Jardine turn-out slash cut exhaust, This think is coming together ,it may see some road time real soon.
