Author Topic: 750K 77 (K7) petcock gasket dimensions  (Read 977 times)
Offline Erny
« on: May 07, 2018, 05:00:47 AM »
Can someone please provide dimesions of gasket beween petcock and tank? Also if shape is flat rubber or O ring?
I can make it manufactured locally but need to know dimensions
My estimation would be 14.5 x9 x2 mm, flat.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 750K 77 (K7) petcock gasket dimensions
« Reply #1 on: May 07, 2018, 06:38:46 AM »
Are you replacing the filter too? The replacement filter comes with a new seal, Honda P/N 16952-388-015.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Erny
« Reply #2 on: May 07, 2018, 07:00:38 AM »
I do not plan to replace filter. And buying whole kit for 40usd (incl shipping to Europe) is simply too much for gasket only
« Last Edit: May 07, 2018, 07:08:39 AM by Erny »
Offline Phinn
  • Subversive
« Reply #3 on: May 07, 2018, 02:08:27 PM »
It's definitely flat. I had to cut a larger one to make one that fit.
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline Erny
« Reply #4 on: May 07, 2018, 11:17:13 PM »
And dimensions? Thickness?
Offline Phinn
  • Subversive
« Reply #5 on: May 08, 2018, 08:19:12 AM »
I didn’t measure it. I just cut a hardware store faucet washer down to fit inside the petcock’s threads. The inner hole was pretty large, leaving the remaining surface no more than 2mm wide. The thickness (which was probably SAE) was pretty close to 2mm, maybe 1.5mm. It works fine.
« Last Edit: May 08, 2018, 08:21:44 AM by Phinn »
Offline johans
    • corporate leather
« Reply #6 on: May 08, 2018, 08:53:24 AM »
I'm getting a new original petcock for a 78k tank this week, i can measure it for you if u can wait a few days.
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
Offline Erny
« Reply #7 on: May 08, 2018, 09:03:05 AM »
Sure, it will help! Thanks
