Author Topic: 2 cylinders  (Read 889 times)
Offline dubman59
2 cylinders
« on: May 11, 2018, 08:05:34 PM »
Hi There,
My CB650 1981  has stopped running on No1 and No3 Clylinders. Any ideas why would be really appreciated .
Cheers Steve
Re: 2 cylinders
« Reply #1 on: May 11, 2018, 08:31:31 PM »
 plug caps, carbs plugged, plugs fouled, lack of compression, bad gas, Have you check anything yourself yet? Such as spark at those plugs, has it been running recently or did you pull it out of storage?
Offline dubman59
Re: 2 cylinders
« Reply #2 on: May 11, 2018, 10:59:42 PM »
Done all that Don
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: 2 cylinders
« Reply #3 on: May 12, 2018, 06:14:44 AM »
did you pull the carb bowls for the offending cylinders to check for a stuck or low float?
cb750 k6 - ugly
Offline DaveBarbier
Re: 2 cylinders
« Reply #4 on: May 12, 2018, 06:29:32 AM »
Done all that Don
Sorry, but that’s not good enough of a reply if you want help.
Answer these questions:
Has this bike ever run on all cylinders in your possession?
How are you determining you’re running on only #’s 2&4?
Does it do it all the time? If not, elaborate.
Explain how you “did” all the stuff that Don listed.
Is your battery freshly charged and holding a good charge?
Have you performed the 3k mile maintenance checklist?
Offline BobR
Re: 2 cylinders
« Reply #5 on: May 12, 2018, 06:51:25 AM »
Done all that Don
 +1  and add to that as Don R asked- has it sat for a long time unused?  Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
