Author Topic: Which size carb for 1000cc?  (Read 6751 times)
Offline afkrejci90
« on: May 12, 2018, 11:13:32 am »
Resurrecting my 1000cc race build.  Have a set of Weber 40 DCOE's I was going to throw on there but getting them fitted is taking more time than I would have thought.  Down the road these will be going on but I want to get this thing going so I am going to throw on a set of Keihin CR's.  That being said which diameter would be better suited for this displacement, 29mm or 31mm?  Head has been ported with larger valves.  I read somewhere on here that 31's throw in too much fuel and foul up plugs, but would this be an issue with the increased displacement?
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline cbr954
Re: Which size carb for 1000cc?
« Reply #1 on: May 12, 2018, 11:17:57 am »
Im running CR31 on my street 970cc no issues, the CR is very tuneable
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline slikwilli420
  • Master of Disaster
« Reply #2 on: May 12, 2018, 11:19:04 am »
You won't regret making the Weber carbs work. A superior carb to many others out there. For street use people really like Mikuni RS34.
Offline afkrejci90
« Reply #3 on: May 12, 2018, 11:23:12 am »
A don't doubt that, but to get them to work everything has to made from scratch.
'80 CB750C - Sold
'06 CBR600RR
Offline RAZZ
« Reply #4 on: May 12, 2018, 12:13:02 pm »
Hi take a look at This Weber thread, it learned me a lot, they are time consuming to sync. but alsoluty worth it. Weber carb set-up
https://r.tapatalk.com/shareLink?share_fid=13548&share_tid=68065&url=http%3A%2F%2Fforums%2Esohc4%2Enet%2Findex%2Ephp%3Ftopic%3D68065&share_type=t
Offline RAZZ
« Reply #5 on: May 12, 2018, 12:16:54 pm »
Here some pics of my “Stock” setup
Online MRieck
« Reply #6 on: May 12, 2018, 12:33:40 pm »
I run RS-34's with 1000cc. Work very well....tuned with an onboard A/F meter.
Offline RAZZ
« Reply #7 on: May 12, 2018, 12:38:51 pm »
Here a set of RS34 for sale: CB750  special, rare, and go fast parts - REDUCED again~~
https://r.tapatalk.com/shareLink?share_fid=13548&share_tid=170441&url=http%3A%2F%2Fforums%2Esohc4%2Enet%2Findex%2Ephp%3Ftopic%3D170441&share_type=t
« Reply #8 on: May 12, 2018, 01:49:07 pm »
My CB750 K6 has 71.25 mm pistons. Carbs Mikuni TMR32 works really good but are not cheap.
CB750 K6-76 1005cc JMR Billet block.
« Reply #9 on: May 12, 2018, 05:56:51 pm »
What problems are you having with the Webers?
Online MRieck
« Reply #10 on: May 12, 2018, 06:17:08 pm »
They are really nice carbs. ;)
« Reply #11 on: May 12, 2018, 06:34:15 pm »
Show us what Webers and manifold you got plus anything you can hook the throttle cable to.
 Usually can be running in an afternoon, if they have been on a  running bike before.
« Reply #12 on: May 12, 2018, 06:42:47 pm »
Offline afkrejci90
« Reply #13 on: May 12, 2018, 08:25:13 pm »
The lack of a manifold.  Tried machining my own but ran into some problems due to inexperience.
'80 CB750C - Sold
'06 CBR600RR
« Reply #14 on: May 12, 2018, 08:52:51 pm »
Do you have a drawing ?
 If you look at the RC manifold closely..
 You can machine 4 tubes and press them into a plate.  Lictite them in.
 May have to leave the hole in the tubes undersize, then port it, hand finish to get a good matchup.  Some throttle bits you can make or maybe buy.  We can help you with the manifold, but it means a bit if lathe or mill work.
Offline gschuld
« Reply #15 on: May 12, 2018, 09:31:50 pm »
Rc manifold for reference
George
« Reply #17 on: May 13, 2018, 12:10:57 am »
Mike, have you tried TMR’s on your CB750 yet? I guess you have a set....
I use CB750 throttle control with wires. I need to be very focused when taking off and riding slowly on first and sometimes second gear. Gear ratio is tough. Full throttle less than 1/4 turn. No sneezing allowed!!
RS34’s are easier to handle?
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #18 on: May 13, 2018, 05:40:05 am »
i have a mpd manifold under the bed  ;D
Online MRieck
« Reply #19 on: May 13, 2018, 07:11:56 am »
I have a set of 32's and 36's here but haven't used them Per. The RS's are pretty good especially using the 77/78K reproduction insulators from Vintage CB. Stock cables work great. I am surprised you were able to use the stock throttle cables for the TMR's. When I mocked it up it looked no good and when I bought the 36's different length cables were specified. Interesting.
 They only problem I encountered with the RS's turned out to be a defective float. #1#3 and #4 were burning nice but the A/F was wonky and #2 was rich. Played with height 3 or 4 times and fiddled with the idle screw/pilot jet etc. Finally bit the bullet and bought a new float and problem solved. The rack of 34's was brand new when I bought them. Go figure.
« Reply #20 on: May 13, 2018, 10:48:22 am »
I have photos in my computer home about the cable installation on the TMR’s.  I’m in Spain now close to Benidorm, so no garage nor riding. Sunshine, sea and beers are OK too.
I know that I had to add an extra nut I made a cut in by a saw blade for the wire to use the nut as adjuster or lock nut. Nut is open so not tight too hard, lock with Loctite. One cable is a little bit long, front adjuster at the switch/ throttle is in outest position. Maybe I can adjust at the carbs a little bit more.
Edit: Here photos when I installed them
http://forums.sohc4.net/index.php/topic,61168.msg1660522.html#msg1660522
Jetting sorted out since then
Pilots 30
Fuel screws 1 1/2 turns out (stable idle and less need of choke)
Needles 2:6
Mains 135 (more open pipes 137.5)
« Last Edit: May 23, 2018, 12:17:54 pm by PeWe »
Offline turboguzzi
« Reply #21 on: May 13, 2018, 11:54:55 am »
you said race bike... if it's for AHRMA the only CR are accepted IMHO, would say 31
Offline Bill/BentON Racing
    • BentON Racing
« Reply #22 on: May 13, 2018, 07:18:45 pm »
I might need that, pic please
BentON Racing Website
BentON Racing Facebook
« Reply #23 on: May 13, 2018, 09:43:58 pm »
What is the "that" you might need, Bill??
    • BentON Racing
« Reply #24 on: May 14, 2018, 03:29:56 am »
Lol, I thought I quoted Medyo,  I'm interested in the MPD Weber manifold.
