Author Topic: Short Cut?  (Read 2131 times)
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
Short Cut?
« on: May 16, 2018, 09:00:41 am »
If I warm up the engine, is there anything wrong with adjusting the cam chain by ear?
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Re: Short Cut?
« Reply #1 on: May 16, 2018, 09:05:19 am »
Dont forget heat expands stuff...
If your cam chain plunger has been pulled, cleaned, and slides easily, do the adjustment on a cold engine and forget it.
If you are trying to quiet your engine, no need to spend time here.  Set it and forget it.
Spend your time on valves, timing and carb vacuum sync...
Re: Short Cut?
« Reply #2 on: May 16, 2018, 05:20:05 pm »
 If its for a K1 the adjuster is just a spring loaded device and won't set anything. Be best to follow the instructions in the book.
Offline Phoenix
Re: Short Cut?
« Reply #3 on: May 16, 2018, 08:34:54 pm »
What I mean is I loosen the shaft then push it in until I get the least noise while the engine is running.
Ed Spengeman
Indy
Re: Short Cut?
« Reply #4 on: May 16, 2018, 09:16:51 pm »
Do it by the book.
Short Cut?
« Reply #5 on: May 16, 2018, 11:31:06 pm »
First time I followed the thin Honda manual/users guide I got with the bike. That did not work. To adjust when idling. Better when engine is not running.
Not properly adjusted ignition cause chain rattle.
« Last Edit: May 17, 2018, 12:27:48 am by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline pjlogue
Re: Short Cut?
« Reply #6 on: May 17, 2018, 01:25:42 am »
15 deg. PTDC, bike cold, engine off is the only way I know that works.  Doing it while engine is running will leave you with way too much slack in the chain and an engine that sounds like a cheap sewing machine.  If I remember correctly, the '76 owners manual was wrong.  They left out the 15 deg. PTDC part.
-P.
Online Don R
Re: Short Cut?
« Reply #7 on: May 17, 2018, 01:28:03 am »
 Remove the adjuster and check to see if the shaft is dinged by the pinch bolt and stuck. You might need a gasket.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Short Cut?
« Reply #8 on: May 17, 2018, 04:19:49 am »
Engine off to adjust timing chain. The best way to quell the rattles is a good carb sync. ;)
« Last Edit: May 17, 2018, 09:08:37 am by madmtnmotors »
TAMTF...
Wilbur
Projects:
                                           http://oldmanhonda.com/MC/wiring750K1.html
Sent from my Tandy TRS-80!
Re: Short Cut?
« Reply #9 on: May 17, 2018, 06:37:13 am »
Yes, we understood you, but the cam chain adjustment wont get all the noise out.
re-read what I posted.
If you are trying to quiet your engine, no need to spend time here.  Set it (by the book) and forget it.
Offline pjlogue
Re: Short Cut?
« Reply #10 on: May 17, 2018, 07:34:19 am »
What Madmtnmotors said is good advice.  A out of sync. carb will make the motor sound real clackity and the sound mimics the sound of a lose timing chain.
-P.
