Support the site. Your contributions keep this site running.
Prolly need to drill the head of the fastener right off. This is what I did. With the screw heads off (right off with no flange left to hold the case on) then the case can be removed. After that what's left of the screw is easily removed. Worked in my situation.good luck, dj
You need to invest in a manual impact driver, the kind that works with a hammer. I haven't run across a screw yet in a SOHC4 case that it wouldn't loosen. And as a bonus the action of hitting it with a hammer drives the bit into the screw head helping to keep it from stripping out.
