Author Topic: Dynoman contact  (Read 1119 times)
Offline Johnny340
Dynoman contact
« on: May 22, 2018, 10:26:49 AM »
Does anyone know how to contact the folks at Dynoman regarding their Dyna S ignition?  I need a pickup magnet.  Their phone numbers are disconnected and the contact links on their website don't work..
Thanks in advance.
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Dynoman contact
« Reply #1 on: May 22, 2018, 01:07:44 PM »
No problem here
http://www.dynoman.net/contact.html
Tech questions: dynoman2@austin.rr.com
Maybe OK now or your laptop, smartphone?
Offline Johnny340
Re: Dynoman contact
« Reply #2 on: May 22, 2018, 01:36:01 PM »
No problem here
Yup, switched devices and that link worked.  Thx!
They sent this contact:
http://dynaonline.com/contact/contact-us.aspx
Just talked to Larry who took care of me!
Btw, not to start a coil ohm debate thread but he said with his Dyna S ignition, he recommended the 5 ohm coils with all the Honda's less than 750.  The 750 charging system could handle the 3 ohm coils but I'm going to use 5 ohm anyway..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Dynoman contact
« Reply #3 on: May 23, 2018, 09:44:03 PM »
My CB750's charging system was not happy with Dyna-S and 3 ohm coils. Battery drained rather quick. Not possible to have headlight on. I had bought the kit locally so I could go back and switch the 3 ohm coils to 5 ohms and no further problems.
What's the meaning with 3 ohm coils?  Only when running plugs with larger gap?
I used Dyna wires which were no good, graphite core wire that had intermittent function on one cylinder and messed up the carb jetting for long time. Standard wires with NGK 5 kohm caps and NGK D8EA plugs runs fine. Denso X24ES-U is OK too.
