Author Topic: A little help with a blinking m-unit  (Read 832 times)
Offline gjunkie
« on: May 23, 2018, 12:20:31 PM »
Hi there!
I’ve been searching everywhere I can for help on this but can’t find a straight answer. Hoping someone here can educate me a bit.
I have a ‘75 CB400F. I rewired it with an m-unit and has worked great. Recently I removed some unused wires and replaced a few bad ones. The bike has sat around for a couple of years without use (sadly). Now when turning on power I get two blinking lights: Light In and Break In. So as per the troubleshooting directions I figured I had a bad connection. Here’s he kicker.. after debugging for a while I tried to go back to basics and disconnected both of these systems... the lights still blink.
I’m curious if this means one of the following: I have to reset the m-unit, I have a bad m-unit, I truly have a short somewhere and either it or I am confused....
Any help is appreciated. Thanks!
Offline calj737
  • I refuse...
Re: A little help with a blinking m-unit
« Reply #1 on: May 23, 2018, 01:39:40 PM »
Typically an indication of a very bad ground, or, a very weak battery. Does the engine fire?
Offline piefairy
« Reply #2 on: May 23, 2018, 04:20:11 PM »
When I was initially setting up my M-unit, I attached the ground battery terminal directly to the unit to eliminate as many variables as I could trying to cut out variables. But Cal is the expert, he helped me with mine. I just tried to not seem like a complete idiot  ;D
Offline calj737
  • I refuse...
« Reply #3 on: May 23, 2018, 04:52:22 PM »
That is not a recommended configuration. The battery needs to ground the frame and motor. The M-Unit wants a solid path to ground, best if through the chassis.
Offline piefairy
« Reply #4 on: May 23, 2018, 07:05:00 PM »
At the end of the day, I agree, but it was a temporary setup to ensure a good connection for testing. There was a cable to the chassis as well as a cable to the neg of the m-unit, just to ensure a solid connection.
