Author Topic: Spark plugs and HT leads for CB750  (Read 2223 times)
« on: May 24, 2018, 06:02:39 PM »
Hi all,
Been a while since I ordered new spark plugs and HT leads (I have replaceable HT leads - CB900 coils) - looking for a good source to buy from any recommendations? I have a CB750K4 with 836cc kit. Looking to change the plugs and HT leads.
I did do a search but info may be out of date hence the questions.
Thank you!
Andy
Re: Spark plugs and HT leads for CB750
« Reply #1 on: May 25, 2018, 01:54:07 AM »
just use any solid core high tension wire.
« Reply #2 on: May 25, 2018, 03:01:52 AM »
You must have a shop like this in US?  http://www.gsparkplug.com/
I have wires , NGK caps and boxes with sparkplugs, NGK as well as Denso from this UK shop.  Good prices on parts and shipping
« Reply #3 on: May 25, 2018, 03:16:53 AM »
use only ngk or denso plugs.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=70e3eec7i3o5lcrt1te39eee10&/topic,60973.0.html
« Reply #4 on: May 25, 2018, 03:19:00 AM »
 Nippon denso plugs is far better then ngk..
i hate all this v-w.... vords
« Reply #5 on: May 25, 2018, 03:42:50 AM »
  I agree with that.
« Reply #6 on: May 25, 2018, 03:48:14 AM »
champions only come in lawn machines these days,if you buy a new lawn machine swap the plugs for ngk or denso!bosch seem to be colder in the same heat range number to me?
« Reply #7 on: May 25, 2018, 03:58:29 AM »
anyone got any old stock lodge or klg plugs handy?there were so many brands years ago?in the days of low rpm low compression 6 cylinder cars a well timed match or flint would work,these days high rpm and compression really requires plugs that will run at a steady temperature reliably and only a couple of brands shine at this,i wouldn't say denso are far better than ngk,i consider them equal.
« Last Edit: May 25, 2018, 04:00:59 AM by dave500 »
« Reply #8 on: May 25, 2018, 04:14:37 AM »
Based on a recommendation I installed DENSO X24ES-U about a year ago and #4 died on me soon.  So I replaced #4  with NGK and within a month #3 died.
I went back to NGK.
« Reply #9 on: May 25, 2018, 04:18:23 AM »
 I like ngk over denso but will use them both,thing is a lot of fake denso and ngk plugs are out there,if you buy online beware,if from a bricks and mortar seller your safe.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Last Edit: May 25, 2018, 06:01:51 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11 on: May 25, 2018, 04:28:17 AM »
better fine tune that link madmotorman,i got work boots and ladies panties!
« Reply #12 on: May 25, 2018, 04:47:45 AM »
It is being redirected by this forum. Copy and paste the text from link above into the address bar of your browser and it will take you to the spark plug wires page at Lowbrow Customs. I've never seen this sort of redirect on this forum before. I wonder if there have been some changes on the forum server recently?  ???  ???  ???
I'll reach out to Glenn and see what he thinks.  8)
« Last Edit: May 25, 2018, 04:54:20 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #13 on: May 25, 2018, 05:01:15 AM »
I kinda liked the panty ones though!
« Reply #14 on: May 25, 2018, 05:18:40 AM »
I knew you were going to say that!   :D
TAMTF...
Wilbur
Projects:
« Reply #15 on: May 25, 2018, 05:26:20 AM »
your the pervert who supplied the link fella!
« Reply #16 on: May 25, 2018, 05:47:56 AM »
No... we have "Viginalink" to thank for that!  :o  ;D
TAMTF...
Wilbur
Projects:
« Reply #17 on: May 25, 2018, 05:59:42 AM »
The link works as an attachment, just takes a couple of clicks to get there...
TAMTF...
Wilbur
Projects:
