Author Topic: Tank thickness  (Read 900 times)
Offline VTCBike750
Tank thickness
« on: May 26, 2018, 05:24:57 PM »
Does anyone know how thick the metal is on our gas tanks?
I have a '72 and a '71 tank. Any reason the '71 would feel thicker or is it just in my head?
« Last Edit: May 26, 2018, 05:52:37 PM by VTCBike750 »
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Re: Tank thickness
« Reply #1 on: May 26, 2018, 06:58:18 PM »
0.2-0.3mm sheet metal.
Re: Tank thickness
« Reply #2 on: May 26, 2018, 07:41:24 PM »
 That is only 8 to 12 thou, they must be thicker.
Mi am leaning toward 1 mm or more, keep in mind the top is  2 pieces welded and ground off in the middle of the tank.
 Never seen one leak there either.
Offline VTCBike750
Re: Tank thickness
« Reply #3 on: May 26, 2018, 08:37:06 PM »
The tank that I think is a 71 has a different fuel cap and nuts inside to secure the petcock to the tank.
1971:
Sent from my SM-G930P using Tapatalk
-Adam
Offline VTCBike750
Re: Tank thickness
« Reply #4 on: May 26, 2018, 08:37:36 PM »
1972:
-Adam
Offline VTCBike750
Re: Tank thickness
« Reply #5 on: May 26, 2018, 08:40:02 PM »
Ive heard they are 18 gauge, 1/20", 1.27 mm
-Adam
Re: Tank thickness
« Reply #6 on: May 26, 2018, 08:49:48 PM »
First gas cap shown   looks early.
 Is there wrinkles in the tank when you look straight into the filler hole ?
Any evidence of original color?
Offline VTCBike750
Re: Tank thickness
« Reply #7 on: May 26, 2018, 09:12:15 PM »
Not a wrinkle tank. Original color appears to be ruby red.
-Adam
Re: Tank thickness
« Reply #8 on: May 27, 2018, 10:13:57 AM »
Over 1mm sounds thick for me. Anyone that can make a cut in a tank? ;)
Re: Tank thickness
« Reply #9 on: May 27, 2018, 11:28:27 AM »
I have a cut out gas cap somewhere, with several inches of steel on either side, but not nearby.
Someone will have a cutc tank or cutout cap.
Offline DurangoCB
Re: Tank thickness
« Reply #10 on: May 28, 2018, 07:16:17 AM »
The second photo is the cap from a '71.
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
