Author Topic: CB550 Fork Tubes  (Read 1797 times)
Offline separatist
CB550 Fork Tubes
« on: May 27, 2018, 11:01:28 AM »
Does anyone...
1) Know of a good deal for new fork tubes on a CB550 or...
2) Know if CB750 fork tubes can be subbed in? They sure look the same on the interwebs, and it's online so it can't possibly be a lie.
-Sep
Offline separatist
Re: CB550 Fork Tubes
« Reply #1 on: May 28, 2018, 07:31:29 AM »
Seriously, no one? No one knows if CB750 tubes sub for 550s? Seems like a pretty basic question given the rocket-science knowledge of so many people here.
Offline jaytee-nz
« Reply #2 on: May 28, 2018, 02:05:48 PM »
It's not hard to use Google - there's a lot of info out there.
Try this https://z1parts.net/honda-front-fork-tubes-cb750-k2-k6/
They state these fit "some" CB500 / 550's
« Reply #3 on: May 28, 2018, 02:52:10 PM »
750 tubes are longer and there are at least three different damper rod designs over the 69-78 cb750 model run, certain year damper rods may not work with the 500/550 sliders...
Offline separatist
« Reply #4 on: May 28, 2018, 05:44:28 PM »
Jay, I am indeed not brain damaged. I just thought someone might know which "some" and which not. I'll call the guy who sells the part. If the info was readily available on Google I wouldn't trouble folks here.
Offline Robbo
« Reply #5 on: May 28, 2018, 05:54:30 PM »
Sep, maybe start with including the year of your CB550.  Someone with knowledge shouldn’t have to go through all the possibilities with you.
1973 CB350 Four, 1975 CB550K
Offline grades
« Reply #6 on: May 28, 2018, 06:30:00 PM »
I have a 76 550 and 73 750. I compared the two and the 750 forks are about 1.5in longer. Brake mounting locations seem identical but not 100% sure they would cross over. You'd have a tall front end or a lot of fork exposed out of the top of your triples if you swap in a 750 pair. Would most likely need clip ons to prevent them hitting your bars.
« Reply #7 on: May 28, 2018, 11:46:23 PM »
The 750 tubes raising the front end if you do not have extra fork tube exposed above the clamps will cause a steering geometry change to the 550 which will negatively affect your turning. It is better to stick with stock length to retain the superb handling 550 chassis design.
David
« Reply #8 on: May 29, 2018, 12:44:47 AM »
rocket science knowledge?i like the sound of that.
« Reply #9 on: May 29, 2018, 04:46:44 AM »
I know a rocket scientist or two, should I call them?  Nah, it is not in their wheelhouse.
(Serious about knowing a few real life rocket scientists.  Best friend spent several years being one.)
Offline separatist
« Reply #10 on: May 29, 2018, 08:01:15 AM »
Robbo, excellent point. I have a 74 CB550. I also saw the K1 ad and thought hmm, nice price for fork tubes and if I just order the minus-2" size I should be good on geometry. Everything seems very similar, the only different element I can see is that the K1 picture shows a small hole in the indentation that holds the damper on place. I can't imagine what difference that would make but I'm no expert. Grades, thanks for the answer but I want to use just the tubes, not the entire shock.
Offline carnivorous chicken
« Reply #11 on: May 29, 2018, 08:52:54 AM »
I've got a set of 550 forks and triple tree in good shape -- $75 plus postage, let me know if you're interested.
« Reply #12 on: May 29, 2018, 04:30:16 PM »
750 caliper swing arms are different, longer and the disc is different...same wheel hub used by both and early forks used same caliper arm mounting setup.
Fork lowers for 77-78 550 are different (taller) and dispense with the gaiters.
