Author Topic: To use or not to use gasket sealant  (Read 1515 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: May 28, 2018, 04:39:36 PM »
I have the alternator and shifter covers off of my 750. I didn't realise that the alternator cover didn't have to come off to remove the starter. Before, when I had to replace them, I using gasket sealant. Is this really necessary to stop oil leaks? I ask, because there is a good possibility I will have to remove the starter again, and scraping the old gasket and sealant is a pain.....and it makes the covers harder to remove.
Now that I find that I can buy individual covers....rather than kits...maybe I should just buy more of these covers!  :D
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Re: To use or not to use gasket sealant
« Reply #1 on: May 28, 2018, 05:03:20 PM »
If you are using the stock gaskets then no gasket sealant should be necessary assuming the surfaces are super clean before using the OEM gasket. Gasket sealant was never used by Honda.
Offline beemerbum
« Reply #2 on: May 28, 2018, 05:07:13 PM »
+1. The only place gasket sealant is necessary is joining the case halves.
Offline techy5025
« Reply #3 on: May 28, 2018, 06:00:52 PM »
Thanks for the info! I'm using the Athena gaskets. Everyone seems to like them and they are readily available so hopefully they are OK.
Jim
2003 CBR600F4I
« Reply #4 on: May 28, 2018, 09:34:10 PM »
No leaks even with the cheap gaskets. The cheaper gaskets have not as good fitment as Honda's. Some holes do no match. The cheap gaskets are not cheap enough for the lousy quality.
