Author Topic: Newbie but old member  (Read 904 times)
Offline Bennyander
« on: June 02, 2018, 07:55:39 AM »
Hi folks! Im Benny Andersen, living in Glasgow Scotland. I have re-inherited my old CB650 1980/1 from the friend I gave it to many years ago. He wanted to move on and did not know what to do, so I got it back. I was a member of the SOHC/4 Owners Club back in the early 2000's, and have rejoined as I need some help with repairs to do on the bike. The head needs to come off as I have oil burning in cyl 1, a valve stem oil seal issue I think. Also some of the cam cover bolts are threaded/stripped so these will have to go to an engineering shop for repair.
Anyway, its nice to be back.
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: Newbie but old member
« Reply #1 on: June 02, 2018, 03:44:11 PM »
Welcome from the shores of Lake Superior.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline calj737
  • I refuse...
« Reply #2 on: June 02, 2018, 03:53:08 PM »
Welcome back. Those stripped bolts shouldn't require a machinist to remove. Grab a set of left-hand drill bits. Use a small one to create a pilot hole, spinning your drill in reverse. Then graduate through the size, staying below 6mm as the cover screws are that size. The reversing action of the LH bit will generally turn out the screw.
Spin them slowly and use a punch first to orient your bit.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #3 on: June 02, 2018, 04:52:36 PM »
Welcome back Benny.  Is the bike a Standard vs a Custom?  Would like me to add you to the 650 Owners List?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Bennyander
« Reply #4 on: June 03, 2020, 02:57:54 AM »
She’s a bit of both Standard and Custom. I bought her from an importer in Matlock Derbyshire who sent me enough bits to make one good bike out of a pallet loaded with bits. Some were 1980 and others 1981, some standard and some custom as you will see from the photo. She’s always been a lovely bike to ride but I’m now having issues with the breather pipes around the carbs, perishing, leaking, bits missing. Any help would be appreciated
« Reply #5 on: June 03, 2020, 07:05:59 AM »
Welcome from Texas
