Author Topic: Machine Shop Work  (Read 949 times)
Offline Sean CB550
Machine Shop Work
« on: June 03, 2018, 07:59:07 PM »
Hello all! I have a lot of aviation mechanical experience but no major motorcycle experience. I purchased a CB550 that was in seriously bad condition and I’m now going to bring the old girl back from the dead. The engine needs some welding and machine repairs—one of the exhaust studs pulled out on the previous owner and took a chunk of aluminum with it. I’m in the south central Wisconsin area, does anyone know of a good machine shop in the area? Any good shops that I could ship too?
I’m super excited about this project.
Offline Scott S
Re: Machine Shop Work
« Reply #1 on: June 04, 2018, 03:39:44 AM »
 It would probably be easier and more cost effective to just replace the head.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline calj737
  • I refuse...
« Reply #2 on: June 04, 2018, 03:46:30 AM »
Its tricky, but not impossible to weld these cast aluminum cases and heads. Traditional TIG welding tends to bring up a lot of porosity in the cast parts, so extra care must be taken. If you need to "build up" an exhaust stud boss, then layers of filler with peening in between is needed. Some times, its easiest to fill the entire stud hole, then re-drill and tap the hole. All depends...
I don't know a shop local to you, but I do have a very good machine shop local to me in Richmond, VA. You could reach out to the folks at CycleX (who are in your neck of the world) and see if they are able to do the welding repair, because they certainly can do the machine work.
