Author Topic: CB400F gearbox in Cb350F  (Read 2213 times)
Offline andyman
« on: June 12, 2018, 12:03:50 PM »
Hey Guys!
I want to put a 400F sixspeed gearbox into the 350F crankcase. Is that possible? Is the clutch different?
Thanks for answering!
Andy
Offline innovativems
    • Innovative MotoSports
« Reply #1 on: June 12, 2018, 12:12:47 PM »
I believe the cases are different between the bikes so I don't believe the trans would be interchangeable.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline carnivorous chicken
Re: CB400F gearbox in Cb350F
« Reply #2 on: June 12, 2018, 12:24:32 PM »
Why not the whole engine? It's bolt-on, with a few minor tweaks (rear brakes, e.g.) and 50cc more.
Offline andyman
« Reply #3 on: June 12, 2018, 12:39:30 PM »
Because its a racer and it is not allowed to have more than 350ccm.....
Offline Bodi
« Reply #4 on: June 12, 2018, 04:10:03 PM »
I think a 400 lower case with 350 barrels might work. I believe they both have 50mm stroke?
The clutch actuator is different, 400 has it a covered lever the end of the clutch cover and the 350 has the external lever.
I don't know if one could swap in the transmission shafts and shifter bits though. Not a normal kind of "upgrade" for most of us.
Offline knowsnothing
« Reply #5 on: June 13, 2018, 12:06:17 PM »
Ahh ok then.  I seem to remember that the oil passages don't line up so swapping the jugs isn't a simple thing.  I also seem to remember the transmissions not being swappable either due to size differences.
So, think outside of the box a little, if what bodi says is true, that both have 50mm stroke, it might be possible (probably not cheapest) to re-sleeve the 400 with jugs to fit a 350 piston???  Would need to make sure everything lined up of course
1978 CB750k Blue - for sale
« Reply #6 on: June 13, 2018, 01:59:26 PM »
Nikasyl coated alloy liner.
« Reply #7 on: June 13, 2018, 02:11:05 PM »
I thought there was another thread where eople that race the 350/400's were saying the five speed is better for racing
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
