Author Topic: 1974 CB750 Offset sprocket Issue  (Read 641 times)
Offline JonathanHValencia
« on: June 14, 2018, 06:26:24 PM »
Hey guys,
I got a rear and front sprocket spacer on my CB750K to run a wider rim and tire. When I go to put the bolts on the studs are too short after the spacer is on. Anybody ever encounter this? If so, what’s the remedy ?
Re: 1974 CB750 Offset sprocket Issue
« Reply #1 on: June 14, 2018, 09:27:00 PM »
No room for the washers, and hardly enough for the bolts to catch. I clearly can’t ride like this.
« Reply #2 on: June 14, 2018, 09:40:29 PM »
Longer studs but I am not sure if they thread in.
Offline Marks78
« Reply #3 on: June 15, 2018, 05:42:51 AM »
What 754 said ^^^ definitely the easiest way to go if the studs can be replaced with longer ones.
If not would it help/be possible to change the offset of the rim (enough to fix the problem while keeping the rim centered in the swingarm) by loosening then re-tightening the spokes so the sprocket side of the hub was farther to the left?? That may create clearance issues with the brake rod or other stuff!?!?
Current Stable:
1978 CB750K
1982 XT200J
1982 XJ1100 Maxim
1985 V30 Magna
1998 VT1100 Spirit
2006 GoldWing
« Reply #4 on: June 15, 2018, 08:35:37 AM »
So I can pop these studs out and re feed longer once from like ace hardware? I didn’t know they came out.
« Reply #5 on: June 15, 2018, 08:41:42 AM »
Pull it off and have a look, not sure what holds them in.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: June 15, 2018, 10:21:17 AM »
Hey guys,
You can also buy a rear sprocket with a dish to it so that spacers are not required.
