Author Topic: Where can I get a valve spring compressor tool  (Read 2169 times)
Offline Coredozer19
« on: June 17, 2018, 02:58:36 PM »
I need the tool to take the valves apart in my 73 350f. Which kind do I get. Where do I get it.
1973 Honda CB350F
Offline Bankerdanny
  • Endeavor to persevere
Re: Where can I get a valve spring compressor tool
« Reply #1 on: June 17, 2018, 03:13:11 PM »
I had to do a head replacement on a scooter project I did a couple years ago. I got my compressor tool from Ebay. I'll see if I can track down the brand.
Offline camshaft1991
« Reply #2 on: June 17, 2018, 03:34:14 PM »
Yeah easy as eBay
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F332044218298 YouTube has videos on how to grind your valves by hand
Also get a magnet pan for valve pins. They’re one of the smallest components on an engine
« Last Edit: June 17, 2018, 03:37:28 PM by camshaft1991 »
Offline Coredozer19
« Reply #3 on: June 17, 2018, 07:39:35 PM »
Hey thanks for the link. I’ll order it tomorrow.
1973 Honda CB350F
Offline Bankerdanny
« Reply #4 on: June 17, 2018, 07:41:20 PM »
Yep, that's the same one I got. I should work just fine.
« Reply #5 on: June 18, 2018, 06:56:04 AM »
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: June 18, 2018, 07:56:05 AM »
I also have that unit and for less than a 20$ bill it is adequate for most jobs.  Larry
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=l70hd0nv4sj65jbcukds0rgq72&/topic,60973.0.html
« Reply #7 on: June 19, 2018, 01:51:09 AM »
i hate all this v-w.... vords
« Reply #8 on: June 19, 2018, 03:42:54 AM »
There is a video of a guy using socket and hammer to get the retainer off.  From what I remember, he puts the head on a folded towel,  holds the socket on top of the retainer and hits it hard with a hammer.
Offline MoMo
« Reply #9 on: June 19, 2018, 04:53:30 AM »
 :-X
That definitely works.  The towel under head is extremely important otherwise you will bend a valve...........that is from experience :-X
Offline jgger
« Reply #10 on: June 19, 2018, 05:14:44 AM »
I saw a video of an actual tool for that, it even had magnets to catch the keepers. Plus you could use it to install the keepers with one hammer whack. Not sure but I think Leslie was the manufacturer.
Offline Bankerdanny
« Reply #11 on: June 19, 2018, 07:13:02 AM »
The actual tool is $20, why bodge up a tool and risk damaging your head or bending a valve to save $20?
Offline 74cb750
« Reply #13 on: June 20, 2018, 02:52:49 AM »
I'd just buy one on ebay for quick and easy, but.....I believe there is no soft "block" included.  I would just make one and place a strong magnet on the compressor to pick up the tabs.
Laugh at least once a day.
Life  $ucks, then you die.
« Reply #14 on: June 22, 2018, 12:58:42 AM »
I just made an adaptor to suit on the automotive one I had,i use this to re-assemble,ive always used the rag under the valve and strike the cap wih a socket and a rag over to catch the keepers = too easy,some ham fisted people get hammers wrong?
