Author Topic: CB400F Front brake grabby  (Read 663 times)
Offline Athame57
  • Athame57
« on: June 23, 2018, 06:29:29 AM »
Looking through previous owners MOT documentents I saw an advisory to one saying the front brake is a bit grabby...it still is. Why would this be happening?
I brake for animals!
Offline Markel
Re: CB400F Front brake grabby
« Reply #1 on: June 24, 2018, 06:33:10 AM »
Put a chamfer on the leading edge of the pads
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #2 on: June 24, 2018, 06:38:01 AM »
Caliper piston is dirty or gummed up. Need to pull the caliper and clean it.
Offline camshaft1991
« Reply #3 on: June 24, 2018, 01:33:13 PM »
Also if your caliper is painted make sure to buy a bleeder kit from 4into1 or buy some clear tubing and use a cup to bleed the caliper and master cylinder. If you set the tube in a cup with a little fresh break fluid in the bottom it should help with bleeding the whole line.
