Author Topic: CB500 Clutch adjustment/movement issues  (Read 4930 times)
Offline Scramps
  • Luke Warm, maybe. Not quite a
« on: June 24, 2018, 03:26:34 PM »
I’m sharing this from my project shop thread to see if anyone may be able to help over here:
Basically what I’m dealing with is that the clutch lever/lifter arm/whatever doesn’t seem to be moving inward enough to push the rod across and actuate the clutch. I have verified the presence of the ball bearing inside the lever, and the rod doesn’t appear to be broken. I may just have something misaligned or not adjusted correctly. Any help would be greatly appreciated
Okay, so, pulled all my components out that are supposed to move the clutch. From what I can tell, I’ve got all the things, but I am absolutely not an expert. Does anyone see anything amiss? Any help would be very much appreciated
Offline hudstr
Re: CB500 Clutch adjustment/movement issues
« Reply #1 on: June 24, 2018, 06:06:48 PM »
Is that the resting position of the actuator in picture number 4? Or were you pulling on the clutch cable? If that is how it normally sits, then your spring might be shot because I remember having trouble getting my spring hooked back up.
Did you loosen the 10mm bolt on the outside to adjust the position of the housing thingy for the actuator? When its all hooked up you should be able to turn it clockwise freely until you feel resistance.
Also you can buy a new bronze ring with the seal for the last picture. I don't know if it matters that much but I do know you can buy them.
« Last Edit: June 24, 2018, 06:10:15 PM by hudstr »
When a passenger of the foot hove in sight, tootle the horn trumpet
to him melodiously at first. If he still obstacles your passage
tootle him with vigor and express the word of mouth the warning "Hi! Hi!"
Offline Scramps
« Reply #2 on: June 24, 2018, 06:27:43 PM »
That was resting position, yes. I greased all those parts back up and put everything back together. I can rotate the adjustment thing through a pretty broad range, but it doesn’t seem to make much of a difference. I’ve also fully adjusted out the cable on both ends, all I’m getting is spring resistance.
I did some reading on here (the search function works again, which is super helpful) and the only thing I can come up with is that my cable is no good. It’s a brand new cable, but i got it from 4into1, and I don’t know if it’s genuine Honda. Also, I’ve got low handlebars, so maybe I need a shortened cable?
Idk
Offline hudstr
« Reply #3 on: June 24, 2018, 07:03:56 PM »
I don't know much about swapping cable lengths but here is a picture of a 72 500.
Offline Scramps
« Reply #4 on: June 24, 2018, 07:43:26 PM »
I’ve gone back through my receipts, and it was a genuine Honda clutch cable that I bought, so I should be able to rule that out as a potential culprit
« Reply #5 on: June 25, 2018, 12:23:00 AM »
is the alloy female thread part with the slot you adjust very worn?sometimes itll let the male thread move sideways some before it moves in the direction it should laterally.
Offline Scramps
« Reply #6 on: June 25, 2018, 06:01:55 AM »
That’s a distinct possibility. It’s currently moving laterally about 3/8”-1/2” when swept, does that sound right?
Offline Scramps
« Reply #7 on: July 01, 2018, 08:07:31 PM »
To follow up here; I believe my problem is twofold. Stuck plates in the clutch basket and possible missing hardware for the springs. I will report back when I know more, because I know how annoying it is to search for a problem on a forum only to have the thread peter out without resolution
Offline Scramps
« Reply #8 on: July 04, 2018, 07:27:56 PM »
Yeah neither of those things seemed to really remedy anything.
Going by the original parts manual, there are Extra washers on each spring, which makes no sense. I’ve tried multiple configurations, but nothing yet has allowed the clutch to move, other than taking out plates. There’s clearly something incorrect going on here, and I don’t have enough patience to try to figure it out in this heat
Online jaytee-nz
« Reply #9 on: July 04, 2018, 08:28:26 PM »
Owners sometimes add extra washers to the springs which has the effect of stiffening the springs and therefore providing more pressure on the plates to fix clutch slip issues.
This shouldn't cause your problems though but it might make the clutch feel stiffer through the lever.
Have you gone through the service manual (page 42) and set everything up as per the instructions ? If not, back everything off and start from the beginning again.
Also have you measured the length of your push rod as they can wear and therefore shorten the distance they will push the "mushroom" on to the lifter plate.
In the service manual it states that you should measure the free play of the clutch assembly (once everything is assembled) and if it is more than .1mm you need to add a shim.
I also notice that you have the clutch plates in backwards - see page 42 again.
I can't remember the length of the push rod but I recall a recent post where someone asked that question so a quick search should find it.
Hope that helps.
Offline Scramps
« Reply #10 on: July 09, 2018, 04:59:13 AM »
That recent post about the push rod length was from my build thread, heh. I’ve redone the installation using the original manual as reference, and the conclusion that I’ve arrived at is that my springs have sprung. They’re about 3.5mm shorter than new ones
Online jaytee-nz
« Reply #11 on: July 09, 2018, 01:00:25 PM »
Yep, that would do it ! Also explains the extra washers.
Glad you found the issue.
Offline Scramps
« Reply #12 on: July 11, 2018, 05:20:22 AM »
Oh yeah no, that didn’t fix the problem.
I’m convinced at this point that the push rod is squished or broken or something. The only thing I’ve been able to find about the dimensions is that it’s 8mm in diameter and 257mm (10.1”) which means there’s about 1/2” missing from mine
Offline Scramps
« Reply #13 on: July 11, 2018, 05:23:18 PM »
I have purchased a steel rod of appropriate diameter, and I intend to fab up a rod of appropriate length when I get home
Offline Scramps
« Reply #14 on: July 11, 2018, 07:49:53 PM »
The rod was the problem the whole time.
I’ve gotta make some minor alterations for fitment, but it works now, so problem solved
Offline Scramps
« Reply #15 on: July 12, 2018, 05:51:45 AM »
The one on the left is the original, the right is the one I made. I guess the PO replaced it with one from a different bike? Idk. Im just glad that the damn thing works
Offline Scramps
« Reply #16 on: July 12, 2018, 12:34:50 PM »
It is very similar, and has caused me a lot of grief recently. I’m so relieved to have finally gotten this problem solved, it was really harshing my chill you guys, like you wouldn’t believe
Offline HondaYo
« Reply #17 on: July 22, 2018, 02:44:21 PM »
Make sure that U harden the ends of that rod otherwise it will shave down and leave nice shavings to be stuck in not so nice places. I tried the cheapskate rod and ended up rebuilding the motor. The original rod is made out of three pieces. Alu in the middle and hardened steel in the ends. I understand that's because the block and the rod are to expand equally with the engineblock to keep your clutchsetting consistent. My rod is made out of 100% hardened steel... :) and I can recognize a difference in adjustment as the engine gets warmer..
Offline Scramps
« Reply #18 on: July 22, 2018, 02:59:53 PM »
So hardening the ends will suffice?
Offline HondaYo
« Reply #19 on: July 23, 2018, 01:49:36 AM »
Mine filed down on the ends aswell as were the rod contacts the steel shroud behind the oilseal. Iwould harden the whole thing to be sure. Keeps it from bending/ flexing to. Good luck!
Offline Scramps
« Reply #20 on: August 21, 2018, 09:20:26 AM »
Late follow up question, where can I find a reliable source of high carbon steel? All the regular hardware outlets that I’ve checked with only offer low-carbon cold and hot rolled stuff. I’m not crazy about the eBay listings that I’ve found, since most of them are either questionable cheap Chinese listings, or the same stuff in US warehouses with badly misspelled listings.
I’m thinking I can use this zinc-plated rod temporarily, but knowing what I do now, I’m loathe to risk it.
Offline Little_Phil
« Reply #21 on: August 22, 2018, 12:42:20 AM »
Search "silver steel", that's what I use. I'm no metallurgist, but it's supposed to be 1.2%. Which is well in the range you need I believe.
Offline Scramps
« Reply #22 on: August 22, 2018, 03:44:46 AM »
Awesome, thank you
Online jaytee-nz
« Reply #23 on: August 22, 2018, 01:08:48 PM »
I'm in the final stages of restoring my 1972 CB500 and another Kiwi CB500 owner here in NZ (who literally has a two car garage full of spare parts) sold me a stainless steel version of the clutch push rod. He had these made and uses them in his own bike. I'll find out shortly if they work or not (just ordered a set of original pipes from Wemoto in Australia to finish off my project) but he swears by his.
Offline Scramps
« Reply #24 on: August 22, 2018, 04:19:20 PM »
Cool deal, here’s hoping that does the trick
