Author Topic: distance between handlebar clamp bolts? cb750k  (Read 1061 times)
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« on: June 26, 2018, 06:09:49 PM »
hello,
just a quick question, what's the distance between the handlebar clamp bolts on a cb750k.  i need a set of bar-backs for my latest project ( 79 gs750 ) and wondering if a honda set would fit, as they're easier to come by.
ctr to ctr on the GS is 35mm, wondering if someone measure their cb750 distance?
thx,
bob p
« Last Edit: June 27, 2018, 05:24:52 AM by steam-powered man »
searching for a dr350se
Re: distance between handlebar clamp bolts? cb750k
« Reply #1 on: June 26, 2018, 08:48:12 PM »
Got a tape ? 1 3/8 is within 3 thousandth of an inch from 35 mm.....thickness of a hair.
« Reply #2 on: June 27, 2018, 05:25:30 AM »
modified the question a bit, thx.
« Reply #3 on: June 27, 2018, 06:35:56 AM »
 So like I said measure your Honda  clamp, or do you not have  a Honda ?
« Reply #4 on: June 27, 2018, 01:39:59 PM »
second sentence, my latest project is a 79 suzuki GS750.  parts and mods are more plentiful for hondas.  : )
Offline kmb69
« Reply #5 on: June 27, 2018, 02:35:36 PM »
The Honda centerline is a bit narrower averaging 32.5mm after measuring a few clamps.
I would guess the nominal designed number is 32mm and that they float some with manufacturing and/or casting tolerances.
« Reply #6 on: June 27, 2018, 07:58:42 PM »
very good, thx!
« Reply #7 on: June 29, 2018, 08:47:18 AM »
I too got 32. 5  mm.
 So if you have an endmill and drill press and were carefull, you could probably move the holes  over 50 thou each hole. That is if you got tgd bsrbacks with clamps. No clamps m you would then have to don't he clamps too.
