Author Topic: 1978 sohc CB750 straight pipes carb issues- HELP!  (Read 3947 times)
Offline freezerburn
« on: June 26, 2018, 06:15:53 pm »
I’m a lurker here but I’ve gained a ton of help from all posters here and I do thank you folks. Progress has been pretty good I’ve mounted both tires, installed a header conversion to run studs, set the valves, rebuilt the carbs and built a nice manometer for syncing the carbs up.
The bike has had a hesitation off of idle and has grayish/tan plug readings and I’m thinking the jets are a tad too small. All other rpms operate perfectly. After removing the jets (pictured) I see a “125” embossed on one and I thought that that was the number I needed but apparently bigger is needed to get it right. The exhaust is a 4 into 4 straight pipes and are really great quality compared to a lot of them that I’ve seen around on the interweb.
Offline freezerburn
Re: 1978 sohc CB750 straight pipes carb issues- HELP!
« Reply #1 on: June 26, 2018, 06:20:01 pm »
More pics to gawk at while you reflect on what jetting I need to try. I’m new to rejecting (properly, lol) and this bike has been run long enough too Lean:(
Offline freezerburn
« Reply #2 on: June 26, 2018, 06:43:18 pm »
Bike-
Offline freezerburn
« Reply #3 on: June 26, 2018, 06:44:22 pm »
Manometer stuffs-
Offline freezerburn
« Reply #4 on: June 26, 2018, 06:46:30 pm »
Manometer completed. I haven’t used it yet because of the rejetting.
FYI it’s running the Dyna ignition and Super Coils but here-
« Last Edit: June 27, 2018, 12:00:35 am by freezerburn »
Offline freezerburn
« Reply #5 on: June 26, 2018, 06:48:10 pm »
On the backside by the stainless bracket are a couple sardine cans with tin lids for the adapters, plugs and stuff.
Offline freezerburn
« Reply #6 on: June 26, 2018, 06:52:39 pm »
The tube lengths, chamber volumes and everything else I could think of are identical to each other. Fun project, I can’t wait to use it once I get carbs right.
Upon reflection I haven’t checked the timing of the ignition where the points were.
Be cool, freezerburn
Please help as Alaska summers are kinda short, lol. fb
« Last Edit: June 27, 2018, 12:03:19 am by freezerburn »
Offline Old Scrambler
« Reply #7 on: June 26, 2018, 08:17:36 pm »
Looks a bit rich...............with pods and those pipes............maybe 115s but check the needles for proper height. Check your timing.........the pipes are blue from burning fuel in the exhaust. I was in Alaska for all of last summer...........it was GREAT ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline freezerburn
« Reply #8 on: June 26, 2018, 08:33:35 pm »
I will definitely need to learn how to check the Cdi timing.
I thought that grayish color plugs indicates a lean condition..?
Can anyone tell me if “125” is something that would be embossed on the Stock jetting as I have on mine I wonder?
« Reply #9 on: June 26, 2018, 08:51:57 pm »
They made them and may have used them or 120,s on earlier 750s with the other carbs. Your came stock with smaller ones..
Offline freezerburn
« Reply #10 on: June 26, 2018, 11:58:38 pm »
Well sheesh. I thought that I would be needing to get bigger jets but I may need smaller ones. As I recall, the the carbs were screwed out 1 1/2 turns  from bottom and that's where I set them back after rebuild. It hesitated before rebuild as well as after.. so maybe turn the screws back in to 1 turn out and go from there maybe. Plus I'll need to confirm the timing is correct first and then I can sync the carbs with my new custom tool:)
Any more contributions or suggestions would be great.
BUT... why are my plugs grey/light tan if I'm running rich? I can't get my brain around that yet   -fb
« Reply #11 on: June 27, 2018, 07:29:05 am »
Here is a video on reading spark plugs from NGK
Offline freezerburn
« Reply #12 on: June 27, 2018, 10:33:26 am »
Nice one BobbyR, thanks! I guess im running more or less right then on the carbs maybe turn the screws in a bit.. now I'm thinking timing of that electronic ignition. I haven't done that before but I do know it's a Dynas Ignition (Dyantek) out of Glendora, Cally. Super Coils too.
Offline freezerburn
« Reply #13 on: June 27, 2018, 10:35:11 am »
A shot of the coils (after I put the tank back on) I was rushed at the last moment.
Offline freezerburn
« Reply #14 on: June 27, 2018, 11:02:17 am »
Float level may be an issue as well I'm thinking. I replaced the current bank of carbs with a cleaner es to begin with and rebuilt them but I didn't check the floats :-[  I've noticed checking around the forum that the float levels for the pdB's are 12.5mm and the A's are 14.5mm (mine are the B's) but I've noticed that some of the owners get the two get confused fairly commonly andwe, it is an old bike that has been through many hands. They may be set at the incorrect 14.5 level.. once this was corrected the online/forum owners reported no hesitation and good throttle responce which are my only problems with the bike. As Old Scrambler mentioned it is probably a bit rich but my needlles are non adjustable for '78/pdB's. It appears no money may be involved which would be great!
Let's see then-
timing,
re do valves post timing change if any,
check float heights,
try out my new manometer, yeehaw!
Can anyone think of any thing to add to check? The input has given me quite a bit of direction and hope let me tell you, thank you all again with any additional guidance and I'll update. I'm gathering info for when I rotate back home in a week or so. fb
« Last Edit: June 27, 2018, 11:17:20 pm by freezerburn »
Offline freezerburn
« Reply #15 on: June 27, 2018, 11:03:31 am »
pdB carb bank-
Offline POPS 911
« Reply #16 on: June 29, 2018, 09:52:53 am »
You can SHIM the needles if you need more fuel, think about it that pointed needle end will be higher in the tube, thin shim. Do you have a stock air box ? You can ride the bike to check lean = pull choke out a little at 3/4 throttle and if bike picks up and run fine = your lean on the main if it blubbers and slows down your to fat. U-TUBE has many sites for tuning carbs for free watching. Make sure those jets are all clean out we use jet drills to clean out the junk from bad gas = soft copper wire will clean most jets but do not run steel wire in those holes. Good JAPAN jets have numbers on the top, CHINA made jets are on the side and hard to read.
Pops
Offline freezerburn
« Reply #17 on: June 29, 2018, 01:20:21 pm »
Thanks pops911 for the write up. I will certainly be trying the choke test! Nice one! I’ve run the bike for at least 500 miles and that tiny stumble off idle is the only problem. A sweet machine and very smooth running.
So far I’ve been told I’m rich, lean and in between plus potential timing is improperly done as well as float level check needed. ALL observations are very much appreciated to compile and assert when I get back home.
No intake boot leaks as ether checks indicated none :)
There was a 4 into 1 header with clamps and I changed them out and put this 4 into 4 on using a diy stud conversion. Anyways, now I can put a centerstand on the bike! I love centerstand sand I just got one on fleabay for $41 free shipping. The 4 into 4 that I have is a nice and high profile and sturdy design as well so I can ride around on the logging roads and dirt. After all this is the big AK.
I think I’ll order the jet set- 105’s x4 through 130’s x4 to have on hand. Are there only those jets plus needles required only or.. are there slow jets, screws etc of various sizes to gather as well? My first time dialing in carbs.. thanks a TON, freeze
Offline POPS 911
« Reply #18 on: July 02, 2018, 05:42:56 am »
Do not mess with needles, main  jets and idle - 1 1/5 TO 2  is a good start turning jet in and out should make a change. Stock air box or [ PODS call for a main jet change ] many u-tube sites show you how to make a change = type in TUNING PODS ON A MOTORCYCLE.
POPS BK911
Offline freezerburn
« Reply #19 on: July 19, 2018, 09:27:15 pm »
A quick update- changed out the pods for k&n filters, I went back into the carbs and indeed the floats heights were all off, air fuel screw o-rings were all hard, #2 carb o-rings were hard, mickey ears needed to be drilled out on one ear. timing was okay but I (static) adjusted it anyway and disassembled, cleaned and lubed plus reassembled the advance mechanism. The three pieces of tubing that were between the carbs (the smaller ones) were loosey goosey and spinning on the nipples. Adjusted valves. All was replaced/adjusted, repaired etc and then I called it a day before attempting to start it up in case I missed something. Haven't used my diy manometer carb sync tool yet.. that will hopefully be the grand finally. Stay tuned and please don't hesitate to contribute. 'freezer
« Last Edit: July 21, 2018, 09:22:26 am by freezerburn »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #20 on: July 20, 2018, 04:54:13 am »
I know the PDA carbs have two sets of rubber crossover tubes, not sure about the PDB. One set of rubber tubes is for the accelerator pump and the other is for the bowl vents (looseness would likely not be an issue with these). If you replaced the accelerator pump crossover tubes then you need to fish the old ones out of the trash and cut out the little brass restrictor so it can be reused in the new tubing. The accelerator pump crossover tubes would be the ones closest to the rear of the carbs.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline freezerburn
« Reply #21 on: July 20, 2018, 08:16:02 am »
The ones that I took off were already replacement tubes alass, no inserts to be had. fb
« Reply #22 on: July 20, 2018, 08:30:18 am »
You can cut new ones from brass or s.s. tubing of the appropriate size if necessary. Whether they are absolutely needed may be open for debate, but I figure Honda had a reason for using them and they are easy enough to replace. I'll have to do some digging, but I know the metal restrictor tubing size has been posted on this forum before.
TAMTF...
Wilbur
Projects:
Offline freezerburn
« Reply #23 on: July 20, 2018, 08:34:51 am »
Cool, I used clear fuel line and will be able to see if it pinches, etc. That was the plan anyway. About to head to the shop and will post any updates this evening. Keep it coming friends  :)
« Reply #24 on: July 20, 2018, 11:30:03 am »
The restrictors in the accel pump tubes I believe were used to balance the flow between the "squirters" in the carb throats. I don't think there is any issue with the tube collapsing, just the potential for uneven flow to the accel pump nozzles? IIRC the accel pump was used to remedy the potential off-idle stumble due to the idle circuit being leaned out a little to meet emissions regulations of the era.
TAMTF...
Wilbur
Projects:
