Author Topic: Rebuilt a carb for my 73 500K2, and there be dragons  (Read 1260 times)
Offline cshanek
    • ahuiz.com/shane
« on: June 28, 2018, 08:42:42 PM »
Good evening,
I have a 1973 CB500K2 that recently had a pretty serious leak coming from my stock carb #2. I bought a carb-rebuild kit, and assembled and installed everything, and the fuel leak stop. Since then I have had difficulty getting her to run consistently. Below are the symptoms.
  • She will only start and run/idle with the choke on all the way
  • With the exception of one time, the second I shut the choke off she dies
  • Light white smoke coming out of pipes
  • Though both pipes are warm the port side pipe seems significantly hotter (carb #1 and carb #2 side)
  • I have tried to adjust the fuel-air mixture screws and any adjustment in any direction seems to make things worse
  • She will cough and sputter a bit at times, almost like a muted backfire. This does not occur regularly
  • I have not played with the throttle screw yet (I read that this sometimes makes a difference even when not at idle?)
Other than bad fuel and a vac leak, what should I be looking at?
Thanks,
Shane
Re: Rebuilt a carb for my 73 500K2, and there be dragons
« Reply #1 on: June 28, 2018, 08:51:44 PM »
Start with the sparkplugs? They should be NGK D7E or ND X22ES-U types. It sounds a lot like they are fouled.
« Reply #2 on: June 28, 2018, 09:00:25 PM »
Because this issue came up before, I must ask how you operate the choke.  You know that lever up is choke on and lever down is choke off, right?
Offline cshanek
    • ahuiz.com/shane
« Reply #3 on: June 28, 2018, 09:01:22 PM »
Correct. Normal operation = choke down, she currently only runs with lever up.
« Reply #4 on: June 28, 2018, 09:06:23 PM »
I'd be suspicious of the pilot circuits, or low fuel level with the selector on normal feed.  Have you tried reserve?
There is a main idle screw on the carbs.  Tried that?  The screw under the grip is just a twist tension adjuster.
Offline cshanek
    • ahuiz.com/shane
« Reply #5 on: June 28, 2018, 09:08:30 PM »
I have tried the main idle screw, have not tried the reserve, will look at the pilot circuits.
Offline cshanek
    • ahuiz.com/shane
« Reply #6 on: June 28, 2018, 09:08:50 PM »
Oh and thanks for the input.
Offline cshanek
    • ahuiz.com/shane
« Reply #7 on: June 28, 2018, 09:09:40 PM »
Thanks for the feedback, I will check the plugs. They were in good shape before the carb rebuild, who knows now.
