Author Topic: Did Oil change today onmy 76CB550F, filter box,how tight and tab needs to go in?  (Read 467 times)
Offline vsanzbajo
In the pic sorry for the low light, it was dark when I finish, Would the tab needs to go in the little channel in top of oli filter box? It looks like it is not leaking, but I wonder if I should tighten more.
Thanks
Offline Bankerdanny
  • Endeavor to persevere
Yes, the tab should fit cleanly into the channel. But just because it is off center a little doesn't mean the housing isn't seated
back off the bolt and jiggle it square as you hold it and retighten the bolt,i like em squared up,if it aint leaking itll be ok though,you only need to crush the o ring plus a little,they aint wheel nuts!
Offline Bankerdanny
Yes, definitely do not over tighten.
