Author Topic: CB400F Carb - springy thing  (Read 834 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: June 30, 2018, 04:28:22 AM »
Last question - for now!
On my recently acquired CB400F2, I took out the carbs to see how bad they were. The answer is not bad at all.
However the springy butterfly thing on top of the main jet is missing on one carb - it shows on the parts fiche I have but has no number and hence no name!! Which I guess also means I cannot get a replacement.
What is this for and can I get by without it? Do any other models use this same part?
Thanks
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Bodi
Re: CB400F Carb - springy thing
« Reply #1 on: June 30, 2018, 05:06:43 AM »
That spring thingy just holds the main jet and emulsion tube in. Unless someone has a junk carb bank and will give/sell you one you are SOL for a genuine replacement.
A few models of Keihin carb have them, definitely the 350 Four and 400F ones.
I went to a hobby shop and got a piece of brass sheet to make one. Not beautiful and not exactly identical but it works. It just has to push up a little, to defy gravity.
Without a spring the jet's O-ring holds it in but I guess Keihin put that there for a good reason. If the jet and emulsion tube drop out from vibration... that cylinder won't run too well at all.
Offline Athame57
  • Athame57
« Reply #2 on: June 30, 2018, 02:09:46 PM »
You are talking about the 'Leaf Spring'. I broke one recently myself and Honda don't make them anymore. However David Silver from whom I get all my new bits were able to sell me one for just £5.00 they cannibalised from one of the CB400f 's they are breaking. https://www.davidsilverspares.co.uk
I brake for animals!
Offline Trevor from Warragul
« Reply #3 on: June 30, 2018, 04:24:19 PM »
PM me your name & address & I'll send you one. Just promise to pay it forward...
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #4 on: June 30, 2018, 11:53:15 PM »
use an "E" clip in the jets slot and a coil spring over the jet long enough to contact the carb bowl and itll hold.
Offline robvangulik
  • Honda Fourever
« Reply #5 on: July 01, 2018, 12:46:45 AM »
Good solution to get home (holiday/long way from home) but any steel object will rust quite easily in that hostile environment, and on the long run a coil spring will cause trouble in the floatbowl!
« Reply #6 on: July 01, 2018, 12:49:28 AM »
the factory leaf spring is #$%*ing steel anyway,you can use stainless e clip and spring,its an old trick itll work forever,the fuel tank is #$%*ing steel,the fuel lines on my car are steel.
« Reply #7 on: July 01, 2018, 12:52:34 AM »
Thank you - very kind. I promise.
I sent you a pm.
CB450 K1 - Stalled.
