Author Topic: Steel CB750 Clutch Lifter Plate - Who Makes Them ?  (Read 1470 times)
Offline whitjonw
  • Motorcycle Maniac
« on: July 01, 2018, 04:47:38 PM »
Someone was making and selling an aftermarket steel clutch lifter plate for CB750's and if I remember correctly, they were around $80 U.S. or so, but I cannot find them. Can someone point me in the right direction ? I of course, cracked my lifter plate upon reassembly of the clutch....even though I was trying to be extremely careful !
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline slikwilli420
  • Master of Disaster
Re: Steel CB750 Clutch Lifter Plate - Who Makes Them ?
« Reply #1 on: July 01, 2018, 05:04:44 PM »
Budman is making billet aluminum ones. I have one in my race bike. Quality part.
Offline whitjonw
  • Motorcycle Maniac
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #4 on: July 01, 2018, 06:08:13 PM »
The most common cause of broken lifter plates is due to misalignment of the splines:
Offline whitjonw
  • Motorcycle Maniac
« Reply #5 on: July 02, 2018, 08:45:44 AM »
I did ensure that they were aligned before fitting the clutch pack to the mainshaft. I did notice that the pressure plate could still be pushed rearward after install and I kept pulling it back toward me to lock it in during the tightening of the mainshaft nut and offering up the springs and lifter plate. It feels like it is aligned correctly if I jiggle it back toward me. Does this sound familiar ?
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #6 on: July 02, 2018, 12:25:31 PM »
I broke one ear long time ago when I was too eager to tighten all 4 bolts. Important to be careful the last part when plate start to get some spring pressure.  A little on each bolt in an x pattern, max 1/2 turn increments. Same when taking it apart the first part when pressure is high.
My stock plate has to hold Barnett CB550 springs that are a little bit harder than CB750 + a washer under each spring to make more pressure. I had some slip before, now not.
« Last Edit: July 02, 2018, 12:27:11 PM by PeWe »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: July 02, 2018, 03:32:09 PM »
Budmans plate is the only way to clutch :-)
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline whitjonw
  • Motorcycle Maniac
« Reply #8 on: July 02, 2018, 05:24:30 PM »
I am buying a Budman billet clutch lifter plate as soon as he gets more in stock. Thanks for the reinforcement !
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline whitjonw
  • Motorcycle Maniac
« Reply #9 on: July 02, 2018, 05:38:09 PM »
Yes, although I was trying to be extremely careful, that is where I blew it...I didn't use an X or cris-cross pattern in my quest to get it done. May or not have been the reason but surely would have been the best way to do it. But, most likely was  :(
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline piefairy
« Reply #10 on: July 02, 2018, 06:58:27 PM »
I managed to catch my plate on one of the seating posts. It was just off a bit, and 1 point got to much pressure and popped when I was trying to balance the torque across the bolts. I bought a NOS replacement, but was stupid careful the second time installing. I am sure the aluminum billet Budman is making is ALOT stronger than the stock cast ones.
Offline whitjonw
  • Motorcycle Maniac
« Reply #11 on: July 02, 2018, 07:00:46 PM »
I have no doubt about that, thanks  8)
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #12 on: July 02, 2018, 10:15:54 PM »
Lube the 2 parts where they slide in together. If they start to bind there's a good chance you may snap a tit.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #13 on: July 04, 2018, 10:12:08 AM »
As you tighten the bolts, they should all feel the same as you go round/across.
If one feels tighter than the others, then the plate is not sitting true.
I just had the one I broke welded; will not know for a while if it works OK though, as I took one out of another motor and it's way down the list for working on.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
