Author Topic: 1973 Cb500 poor boy chop  (Read 23499 times)
Offline Gurp
  • I'm no.......
  • Once was a...
Re: 1973 Cb500 poor boy chop
« Reply #250 on: February 09, 2024, 11:40:55 PM »
thank you guys I'm glad I'm finally back to working on it again.
I love the Kooks! traded for them off a forum member
JakeC I want to say, He is from Seattle my old 4 into 4 pipes in decent shape. these where just right for me! Ordered a similar brake return spring hoping it will work... Fingers crossed ill be able to take it out on the roads in the next 2 weeks!
« Last Edit: February 10, 2024, 10:02:57 AM by Gurp »
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #251 on: February 10, 2024, 10:04:29 AM »
Gonna take a few days to get this glues and cured. I have the time so now big deal. Gonna look for the brake pedal spring a bit today while I watch the kiddos play outside. Hoping I can find it before I have to try the alternative.
Sent from my LE2127 using Tapatalk
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #252 on: February 10, 2024, 01:06:14 PM »
Well I figured why waste the day?
So I got the brake side controls mounted, working and tuned.
I really need to start cleaning stuff before I Tig....
But hey it works and I'm happy enough with that. I can always remake it later it I choose.  I still need to add a round to close up the front of the pedal but it's pretty much done.
Next is welding up the lowered front tank mounts.
After that is adding something to pull the little bit of tail light wire that's resting on the tire.
The. The motorcycle chain sissy bar. I have enough chain to do it once so there is little to no room for error. Debating to take it to my buddy's and use his Mig or stay home and use the Tig.
Now to have a easy dinner night with the kiddos. Momma is at work so I'm going to the local McDonald's with a play place. I'm happy time to make them happy!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #253 on: February 10, 2024, 01:14:59 PM »
Also on the list of things to do. Add some type of adhesive to the throttle side grip as it gentle rotates under load.
Order the Bridgestone trailwing the knobby is ok for testing and around town but I'd like to have a new tire before it gets out further from the house.
Make a battery strap and mount that.
And last but not least find a small GPS for a dual sport and mount it on or close to the bar clamps. I'd like to have the GPS speedo for trips further from the house. When you've been on the highway for a hour or more speed all feels about the same, at least to me it does. It also usually gives me a trip scale of how much gas I have. Time V estimated average travel speed. Less Important going to work but more when I'm out 100+ miles from home.
Offline BenelliSEI
  • 1969 cb750
« Reply #254 on: February 10, 2024, 02:13:46 PM »
How does pulling straight ahead on that brake pedal actually work?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #255 on: February 10, 2024, 04:44:41 PM »
The hole that I tapped for the joint to thread to is in the bottom half and the pedal is slightly off center.
Whole not a effective movement with the slight offset it's enough for it to roll it the way I need to. The Kooks don't lean a lot of room for a more efficient action. I would love to have about a inch more than I do, but that's life.
Offline grcamna2
« Reply #256 on: February 10, 2024, 05:19:31 PM »
I'd also like to purchase a small($) GPS.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #257 on: February 10, 2024, 08:07:08 PM »
Personally I was pretty impressed with how well they function. My Sportster came with a dash that had a 5 inch gauge and I switched it out for an older style they call a cat eye dash. Talk to the guys at work and the cutting me out and adapter to adapt it down to a 3 and 3/8 or 85 mm gauge. And a few thousand miles and over a year out in the sun and the weather the $50 Amazon gauge still works amazing. Just depending on where you are when you turn the bike on sometimes you got to wait a minute for it to get signal but that's not the worst thing ever.
Offline grcamna2
« Reply #258 on: February 10, 2024, 08:15:43 PM »
Do you have a picture,w/ it lit-up ?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #259 on: February 10, 2024, 08:32:25 PM »
Only bad thing about it is it gets a little moisture under the glass. Wouldn't be much of a issue of I currently had a covered place to park the bike. On a wlhot day it's all gone though. I bought the Cheap SOG Amazon brand there were a lot nicer ones I could have gotten that I'll assume weren't so bad about that. If these one ever dies I'll get a snazzier one for the sporty.
Offline grcamna2
« Reply #260 on: February 10, 2024, 09:06:40 PM »
Looks good  8)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #261 on: February 10, 2024, 09:46:08 PM »
Thanks!
After the 500/550 is road ready and had some shake downs the sporty goes back on the lift with a deadline of mid May to get switch over to foot clutch hand shift.
And switching over to a solid rear wheel.
Offline grcamna2
« Reply #262 on: February 10, 2024, 10:48:18 PM »
Thanks!
Going 'old school'
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #263 on: February 10, 2024, 10:51:11 PM »
Always wanted to try it. I'll either like or take it back off and hang the setup on the shelf.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #264 on: February 12, 2024, 10:56:53 AM »
Today ended up being very productive.
Forgot no school for the kiddos so went in the shop to not waste the morning motivation.
Glued another section and moved the clamps for re-foaming the Anti-pod.
Then just decided to see if I could rig up a way to make the chain sissy bar.
Came up with a way using a ratchet strap and running down to vise grips clamped to a piece of wire as a plumb.
It was slow to Tig it. I have to clean up a few of the links. Between the minor rust and the oil/grease I couldn't clean with brake parts cleaner the welds aren't all stunning but that all looks decent.
When the seat comes back I'll weld the bar to mounting brackets and weld the tray to the bar. And probably a tab to the seat as well.
Offline Kelly E
  • Geriatric Hooligan
« Reply #265 on: February 12, 2024, 11:17:32 AM »
Nice job on the sissy bar. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #266 on: February 12, 2024, 08:27:43 PM »
Honestly I've been putting it off dreading building it. Today I just hung it up and wanted to see what it was going to look like. One thing lead to another and 3 1/2 hours later it was done.
A lot of times the perceived notion of how something is going to go stops or slows me down and when I actually do it it's easy.
Offline WhyNot2
  • I'm finally an
« Reply #267 on: February 15, 2024, 08:22:40 AM »
Wow, nice sissy bar. Your notions are as mine......looks hard till you actually do it, then it seems it was easy.
Causes me to put off things as well.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #268 on: February 15, 2024, 10:32:26 AM »
I'm so bad about it. That's how raking the bike was. I dreaded it. Then one day I came home from work and before I even thought what  I was doing....
I HAD CUT THE NECKKK. I was like well no choice but to finish now.
I probably talk myself out of more stuff than I do bc of this. I'm sure if you're like me you do as well.
Offline Shtonecb500
    • Youtube profile
« Reply #269 on: February 15, 2024, 02:37:04 PM »
Nice progress, the forward controls really are amazing, they make a Honda really comfy to ride, the sissy bar looks fun nice work on that. I haven't touched my bikes in months. The end of the riding season was bleak because I had to rebuild my carbs unexpectedly so the last few warmish weeks we had in MI, my bike sat in the garage.The carbs are rebuilt but will need to get synced, the K1 is kinda in the same place and the BMW didn't get touched not even one time, not even a wire diagram for the m-unit was drawn up. I'm in class full time right now learning CATIA, Solidworks, Autodesk 360 fusion and NX...I CANT WAIT TO BE ABLE TO DESIGN CUSTOM PARTS.
Looks good tho, always making me wish I still had a chop floating around...I don't wanna ride one but ill be damned if I don't wanna build and look at one.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #270 on: February 15, 2024, 03:02:29 PM »
I feel that.
Last year end of riding season the sporty went down I rode home with no clutch and parked it.
What is your major studying all that? Digital engineering? Sounds really interesting and difficult.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #271 on: February 21, 2024, 04:08:52 PM »
Kicked the bike over today while cleaning the shop and realized that the kicker was catching on the forward control linkage.
After some aggravated welding I got the kicker reshaped around the linkage.  Unfortunately I don't have the doot rest at exactly the right angle but it's close enough.
May get a gallon of gas and some uni filter oil tomorrow to take it for a ride around the neighborhood.
Right now it's out the Anti-pod on. Retune the carbs. And make a battery hold down.
I ordered a 1973 Ohio plate so I can have a historical plate for it.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #272 on: February 23, 2024, 10:09:29 AM »
Picked up some correct Honda fuel line and some foam filter oil. But today is a no sleep day.
Job Interview this morning then when I got home the woman has to leave for work shortly so I'm awake with my toddler to get the others off the bus and cook dinner. I'll lay down for about a hour tonight then back to work.
Offline Kelly E
« Reply #273 on: February 23, 2024, 12:02:39 PM »
How did the interview go?
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #274 on: February 23, 2024, 12:13:44 PM »
It went great. HR lady said they were all very impressed that I was super relaxed and it came across great.
Panel interview with 9 maintenance and millwright supervisors/managers.
Took my drug test scheduled for my physical next week.
