Author Topic: Wheel Truing Recommendations  (Read 1600 times)
Offline CarbonK
« on: July 02, 2018, 09:20:06 AM »
Hey all. I was wondering if anyone had any preferred or recommended shops to go to get their spoked wheels trued in Northern NJ. How much would a job like this cost? Never had it done and just wanted some info before going in. Thanks!
Offline 34barab
Re: Wheel Truing Recommendations
« Reply #1 on: July 02, 2018, 10:47:27 AM »
In Old Tappan, there's a shop that works on vintage Japanese bikes only.  I'm pretty sure he can true your wheels.  Call Pete at Supercycles, 201-666-1370.
John
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Offline slikwilli420
  • Master of Disaster
« Reply #2 on: July 02, 2018, 12:50:51 PM »
Why not get the tools to do it yourself? Never been a better time to learn a new skill. The tools will likely cost less than a shop will charge to true two wheels.
Online MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: July 02, 2018, 03:30:54 PM »
When I did my K3 750 I bought the stand, wrenches and a dial indicator with a mag base. I watched a bunch of YouTube videos and tore into it. I found it to be a sort of meditation, came out nicely.
I would do it again.
1973 CB 750 K3
10/72 build Z1 Kawasaki
AwesomeCB
« Reply #4 on: July 03, 2018, 03:30:51 AM »
I agree heartedly. It's not as hard as it first appears and there are loads of how-tos here and on YouTube. Start here: http://forums.sohc4.net/index.php/topic,368.html
A truing stand and spoke wrench will run you about $70-ish. A dial gauge and magnetic base, which make the job easier than using the pointer thing on most stands, adds $25-ish.
Offline CarbonK
« Reply #5 on: July 03, 2018, 06:58:47 AM »
I might go this route, only problem is it seems like you need a bit of patience for this which I'm sadly lacking haha.
Nice! About how long did it take for you to complete it yourself?
Offline Brian750
« Reply #6 on: July 08, 2018, 02:04:45 PM »
I just finished truing mine a week or so ago and it is not that bad. I collected as much info as I could, watched videos, set up in my living room, pushed play on The Wire (amazon prime) and went for it. It was my first time and it did take me several hours split up over a couple days but I did it, and I'm not good at anything. I got them within .02 inches. Its not that hard just be prepared to spend some time. Here is a good article by wowbagger.
http://forums.sohc4.net/index.php/topic,157613.0.html
