I still have a miss at part throttle. Things I've done, Changed the carb rack, cleaned the carbs two times myself, a pro once. New fuel pump, several fuel filters usually two inline, dyna ign, 1500 coils checked multiple times, new wires, new plugs twice, new caps, timing belts, idler pulleys, roto rooted the petcock feed, metered the fuel flow, It did run well to Sturgis with borrowed 1100 carbs, that's why I sent the carbs out to that guy for a rebuild. I've also replaced the intake o rings and siliconed the manifolds to the carbs internally. Valve lash, compression test although it was long ago enough I'm ready to check it again and maybe a hot leakdown test. Idle is ok and full throttle is ok, the plugs read good. It has Denso u groove plugs right now. I should have bought the 83 1100 loaner carbs and left it alone when it was at it's best.
