Hi all -
Hoping for guidance/opinions.
My engine is ready for paint (clean spotless took me a week of prep).
Plan A - fail: I wanted to use the VHT stack (primer SP148 + paint SP127). It is not accessible in Canada anywhere (due to rule changes a few years ago).
Plan B: use Duplicolor stack (engine primer 1612 + paint 1615). No primer either in Canada for be same reason. But can easily get the enamel.
I can’t find primer or high heat adhesive promoters anywhere (I am a bit surprises).
Anyway, my question: can I use duplicolor without primer on cb750k engine? And if in the off chance I was able to find high heat premier (non vht and non duplicolor), can I use it with Dupli’s 1615?
Any input/thoughts or experience to share is most welcome. Thank so much in advance.
