Author Topic: Billet CNC Oil Pump Rotors (Now in stock!) - CB500/CB550 anyone?  (Read 16908 times)
Offline MessnerMoto
Now in stock! Price is 120EU for complete set! Shipping is 8EU.
Subject speaks for itself... I will post this in Hi-Po part of the forum first. Before general public gets familiar.
They will be available in 10 days. First run of 50 sets is in production
Material is 4732 steel... Already at around 30 RC of hardness. Superior to original sintered rotors.
And tolerance between rotor tips is going to be less then 0.1mm. Better then original OEM pump.
This will get your oil pump to better then OEM new state and for less then what OEM rotors would cost if they were ever available...
Contact me using PM or info@messnermoto.com
« Last Edit: June 09, 2019, 03:09:24 AM by MessnerMoto »
Re: Billet CNC Oil Pump Rotors
« Reply #1 on: July 09, 2018, 12:30:26 PM »
 Nice, thanks for the time, effort, and massive expense you are putting out.
 It really helps the SOHC community., and is greatly appreciated.
Offline kmb69
« Reply #2 on: July 09, 2018, 12:35:03 PM »
Mirko, That's cool!
Are the radii a proper trochoidal form?
How much per set?
« Last Edit: July 09, 2018, 12:39:23 PM by kmb69 »
« Reply #3 on: July 09, 2018, 01:00:42 PM »
Yeah, and what's in the box?
Offline kmb69
« Reply #4 on: July 09, 2018, 01:06:24 PM »
Spanky, You sure are nosey!  :o
Offline MessnerMoto
« Reply #5 on: July 09, 2018, 01:16:52 PM »
thx guys ;)
Please send me email to info@messnermoto.com or send me PM here for more info.
« Last Edit: July 09, 2018, 01:31:26 PM by MessnerMoto »
Offline MessnerMoto
« Reply #6 on: July 09, 2018, 01:22:04 PM »
Mirko, That's cool!
How much per set?
yep the form is generated using professional software. It is not a duplicate of original rotors...but you will not be able to see the difference
between original and this billet rotor shape with naked eye
Offline slikwilli420
  • Master of Disaster
« Reply #7 on: July 09, 2018, 01:24:40 PM »
Awesome! Email sent.
Email didn't go through. Can you please confirm your email Mirko?
Offline MessnerMoto
« Reply #8 on: July 09, 2018, 01:31:08 PM »
sorry Matt typing error o at the end of info@messnermoto.com
« Reply #9 on: July 09, 2018, 01:50:23 PM »
follow
Offline MessnerMoto
« Reply #10 on: July 10, 2018, 11:24:56 AM »
Things are multiplying;)
« Reply #11 on: July 10, 2018, 04:36:29 PM »
So, how much are these going to cost? This fit both cb550 and cb750?
Offline MessnerMoto
« Reply #12 on: July 10, 2018, 10:08:25 PM »
I sent you a PM message.
I don't think it is compatible with cb550... but maybe somebody can give this info
« Reply #13 on: July 11, 2018, 06:33:10 AM »
Way cool!
Offline turboguzzi
« Reply #14 on: July 11, 2018, 08:39:09 AM »
oh you 750 centric people..... :)
550 has only one rotor to begin with, no return side
the external diameter fo the rotors should be listed in the dimensional wear limit data of both shop manuals,
if same, trimming it to right width shouldnt be an issue IMHO.
but mirko, since it's all CNC and no tooling, it would be just a matter for scaling the CAD to the diameter for the 550 rotors.... the beauty of new mfg...
Offline MessnerMoto
« Reply #15 on: July 11, 2018, 09:17:26 AM »
Maybe you are correct Yoss but there is a fun fact about this gerotors....
When I reverse engineered original OEM rotors I found out that like usual engineers choose round numbers :)
Supply side of pump is engineered that it supplies exactly 5 liters of oil at 1000rpm, return side is exactly 50% bigger and it pumps 7.5L at 1000rpm
...and to get back to 550 oil pump... one important factor/parameter is how much is center of inside rotor is moved from center of outside rotor. If this is exactly the same like on cb750 pump then it is just the matter of scaling like Yoss suggested... I would bet that 550 rotors have exactly the same form like cb750 rotors just they are longer....
Offline turboguzzi
« Reply #16 on: July 11, 2018, 11:00:44 AM »
yep, offset of the shaft is critical. regretfully, the 500 manual only list clearance between rotor and housing, not diameter, so no answer, but i would tend to believe that honda used a single rotor dia/shaft offset for all models around that time, chnaging only width. Kaz Yoshima used GL1000 rotors modified for his 400 for exmaple, but i dont have solid numbers, my oil pump is already mounted..
Offline MessnerMoto
« Reply #17 on: July 11, 2018, 11:52:07 AM »
...So if somebody on this forum can give us some measurements from cb550 oil pump rotors(actual name gerators) that would be great
Offline kmb69
« Reply #18 on: July 11, 2018, 12:48:04 PM »
Appears the CB500/550 gerotors are 4/5, 40.54mm OD, 27mm Wide, 11mm shaft, and 3.4mm offset.
Offline kmb69
« Reply #19 on: July 11, 2018, 12:56:02 PM »
Not exactly. They used 50mm rotors on 13mm shafts in some models - the CB750A for example.
Honda spec'd them, Yamada engineered and produced most of them.
Offline MessnerMoto
« Reply #20 on: July 25, 2018, 06:47:25 AM »
Also small update... close to finish
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #21 on: August 01, 2018, 10:39:38 PM »
Are these available yet ?
Offline MessnerMoto
« Reply #22 on: August 03, 2018, 04:52:50 AM »
yep. Next week they will be ready for shipping
« Reply #23 on: August 07, 2018, 11:07:59 AM »
Nice looking product, Mirko.
Offline MessnerMoto
« Reply #24 on: August 18, 2018, 03:13:25 PM »
