Author Topic: Front Fork Seal - Rough Ride After Replacement  (Read 1509 times)
Offline mgl01
« on: July 09, 2018, 02:50:01 PM »
I replaced the front fork seals on my 78 CB750a and now the ride seems much more stiff that before. I realize it will be now that there are no leaks however its almost as if the whole front end hops. I measured fluid - but it came almost all the way to the top of each fork tube. Any thoughts here? Maybe drain some fluid?
Offline kmb69
Re: Front Fork Seal - Rough Ride After Replacement
« Reply #1 on: July 09, 2018, 03:38:00 PM »
It should definitely not come to the top of each fork tube.
The '76-'78 Honda CB750A shop manual says:
Use only ATF (Automatic Transmission Fluid)
145-155cc (4.9-5.2oz) after draining
155-165cc (5.2-5.6oz) after disassembly
Offline jonnycakes
« Reply #2 on: July 10, 2018, 02:51:02 PM »
what he said
'Matic-Fanatic
Offline garyS-NJ
« Reply #3 on: July 17, 2018, 02:02:04 AM »
I think there's better fork oil choices since the 70's.  Perhaps the OP measured without fully extending the front end ( that's a springs out measurement right?). & perhaps his oil selection was heavy or there's some other stiction problem to be checked with wheel and springs removed.
Sent from my VS987 using Tapatalk
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
