Author Topic: spark plug indexing  (Read 2070 times)
keith64
spark plug indexing
« on: June 05, 2005, 07:41:49 PM »
Has any one used those spark plug indexing washers to index the electrode on the plug to the intake side of the cylinder for more power, and does it make a difference or really work.
Offline oldbiker
  • I HATE RAIN
Re: spark plug indexing
« Reply #1 on: June 06, 2005, 01:39:16 AM »
In sixty years of riding bikes, I have never before heard the suggestion that the position of the plug electrode could make any difference. You could  always try some of those surface discharge plugs that don't have a single side electrode if you want to experiment.
Offline kghost
« Reply #2 on: June 06, 2005, 01:41:09 AM »
Used to be an old race car trick with blower motors (supercharged). I don't think you'd notice any difference on a motorcycle.
Stranger in a strange land
Offline Raul CB750K1
« Reply #3 on: June 06, 2005, 01:43:26 AM »
The position of the electrode have to be aligned with the intake valve, but also with Jupiter and Uranus. That will give an extra 20+ BHP.   ::)
Raul
Offline kghost
« Reply #4 on: June 06, 2005, 01:44:33 AM »
DO you have to have the ball lined up too?
« Reply #5 on: June 06, 2005, 01:46:53 AM »
No, it's enough to have it over the bike's centerline to avoid unbalance...  ;D
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #6 on: June 06, 2005, 04:19:32 AM »
Oh no! You have to ride sidesaddle :o
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
bassrocker
« Reply #7 on: June 07, 2005, 02:46:09 PM »
Just to add a couple cents:
The new mechanic at my local shop just graduated from AMI down in Florida and completed the dyno training as his last course. One of things they focused one was indexing spark plugs.
From what he was telling me, they tried it out on a number of different bikes (I'm also assuming different types), and on every one they saw at least 2hp per cylinder when the electrode was directly facing the intake valve. On a CBR600 they saw 3.5 per cylinder!
I don't suppose you'd get those kind of numbers with a 400/4 or a CB750, but it's interesting that it would make such a difference in some motors. It can probably be partially attributed to the bikes probably all having high compression ratios.
Just thought I'd throw that out there!
Ben
Offline 68grandprix
« Reply #8 on: June 07, 2005, 09:54:28 PM »
Spark plug indexing will commonly see power gains in ineffecient combustion chambers. I assume the Cb750's are relatively ineffecient due to their age? I also know Briggs cart racers index their plugs. Jimmy.
« Reply #9 on: June 08, 2005, 04:33:19 AM »
Ben
I don't want to start trouble but I find 3.5 HP increase per cylinder unbelievable ???. That is about a 14% increase in power from that 600 engine. I've built 600cc engines for roadracing and 14% involves alot of work. This would include really tightening the squish, pistons, headwork with a good valve job. Maybe, and I mean maybe, 3.5 total increase and I wonder if that was an STD figure on the dyno not actual. I also wonder if designer fuel was used.
